Looking for a good suck...
Results 1 to 9 of 9
    Douglas, MA
    Default Looking for a good suck...
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I wonder if a turkey baster would do the job?
    Wags
    seattle
    this is how marine mechanics do it,
    1 drain your milkshake
    2 fill you motor with tranny fluid
    3 remove your distributor
    4 install an oil pump priming shaft
    5 spin oil pump with drill motor( for a while, up to 5 min)
    6 drain this
    7 fill with cheap oil (or same you run, your choice)
    8 repeat steps 5 and 6
    9 fill with the oil you run
    10 replace distributor
    Yucaipa Ca
    I thought this was a Baskin Robbins thread.....
    Douglas, MA
    Quote Originally Posted by 1975sleekcraft View Post
    6 drain this
    I was going to do something slightly different...let me know what you think...
    1) drain the milkshake
    2) fill the pan with diesel
    3) remove the spark plugs
    4) disconnect the wire to the dizzy
    5) crank it over a bunch
    6-10 same as you recommend.
    Los lunas NM
    Not sure that would be a good idea: diesel while a upper cly. lube not a good lube for bearings cam ect.,Just my .02 There is still load on bearings cam lobes and I would feel better with oil or atf. IMO edit: then you got to get diesel out,clean up a mess by making another????
    seattle
    no sure about diesel?????
    you need to pull your distributor, and twist the pump, not turning the engine over. it is very easy. you can buy the pump turning extension at harbor freight.
    you dont have to use tranny fluid if you perfer not to. just do the oil cycle more times.
    Member Dave01's Avatar
    Sep 2008
    NH
    Instead of all diesel use a few quarts of diesel with the rest being regular oil. Or, what I've used is Rislone, it did a great job getting rid of the creamy gunk. Run at idle for 5 minutes, don't rev the engine. As long as you've done a good drain and re-fill first I think its fine to run the engine rather than spin the oil pump. Then do the drain and re-fill with clean oil, run a short while, and do a final drain and re-fill.
    '86 Eliminator Sport 20, Chevy 454, Berkeley 12JG w/jetovator
    Senior Member Ken F's Avatar
    I've used diesel plenty of times. even done it to Mercedes Benz engines.
    It's diesel oil. Oil. it works fine.
    Ken F
    The liberals are asking us to give Obama time. We agree and think 25 to life would be appropriate.
