Ride plate/shoe question
Results 1 to 11 of 11
    Senior Member lbhsbz's Avatar
    Long Beach
    Default Ride plate/shoe question
    so, I'm gonna whip one up...
    If I hold a straight edge on the keel, everything behind the intake is 1/4" higher than the level of the keel. Tom at JBP told me I should have nothing hanging below the keel.
    My plan is to make a 1/4" shoe/ride plate combination. I will make the surface behind the intake EVEN with the keel, which seems to be the objective. My intake, and the area that I have behind the intake is 7" wide (give or take)...and the keel (flat keel) is 10" wide.
    Would it be more desirable to make the entire keel/ride plate 7" wide?...or keep it 7" wide until I get the to the back of the pod, and then flair it out to 10" to extend the ride plate keep it the entire width of the keel?
    Here's a pic of the back of the boat...cuz we all like pics, and for reference.
    you can see the 7" wide raised area I'm talking about in the center of the keel.
    Ladera Ranch
    Ride plate should be as wide as the shoe. Any wider and it will cause drag.
    Here's a homemade "bolt" on plate I made. I can't remember the dimensions right now, maybe I'll get them tomorrow when I'm workin on the boat. Can't really tell if it did good, or made things worse though. I would assume it made things better, but I never did a back to back test with it, only have for when setting the plate.
    Long Beach
    Tony...that's exactly what I was looking for.
    Thanks.
    Ladera Ranch
    Compare to a real shoe and you will see why that wont work well... Better off dragging a bag of rocks behind you as it would take less work to make and give the same results.
    [QUOTE=lbhsbz;726461] Tom at JBP told me I should have nothing hanging below the keel.
    QUOTE]
    Sort of ... I said put a straight edge on the keel and see what you got then we work from there ...
    Long Beach
    [QUOTE=jetboatperformance;726814]
    QUOTE]
    See...I listened (for once) I did that and had 1/4" gap in the back.
    Long Beach
    I'm assuming that you are refering to the interface between the shoe and the contoured section for the arc in the intake....so there isn't a big "parachute" there...right?
    I have come up with a couple ways around that, but we'll see.
    I seen it work well on another boat, so that's why I tried it And I'm a getting another intake cut right now for a before and after test
    Ladera Ranch
    Quote Originally Posted by Pw_Tony View Post
    Okay, let me adjust what I said-perhaps it will help a boat that needs to load the pump more, but a real shoe compared to that plate....Aint buying it.
    Ladera Ranch
    Yes that is what I am referring to. There are other design considerations that that plate cannot address...for example, a backcut or taper...
