Originally Posted by
lbhsbz
Ballast resistors are only necessary, along with that yellow wire from the starter "R" terminal to step down voltage to the stock points to around 6 volts while running, from 12 volts while starting. They are not necessary and probably won't even work on an HEI setup.
Some Mallory unidark distributors required the ballast resisitor to be used, but a mag pickup distributor should not. Read the instructions.
I mounted the coil to back of one of the heads...seems not to get too wet back there...at least not wet enough to cause any problems.
