Lost 200rpms
Results 1 to 10 of 10
Lost 200rpms
    The Man cordog009's Avatar
    East Texas
    Default Lost 200rpms
    First time I took the boat out, it turned 5000rpms. Didn't have my gps so not sure what the mph was. Sunday I took it out..same setup with a 2* wedge and bowl transition adapter "rooster booster" and it only turned 4750-4800. Although it was about 30* warmer this time around. Does that sound right to lose that many rpms?
    1984 Youngblood TX-19 SOLD
    humidity and temp prob to blame cory, the air here is shitty right now.
    East Texas
    Yea, it was bad hot and humid the other day. Was March the first time I took it out and was pretty cool outside...but atleast now it throws a better tail
    Sep 2008
    Yuma, Az
    Pics.
    boatless....
    East Texas
    Quote Originally Posted by YumaJet View Post
    Pics.
    Should have some this weekend..my daughter tore up our camera and I've gotta pick up another one before we head to the lake.
    B1 Racing cs19's Avatar
    yep
    B1Racing.net
    What was your engine water temp for both trips?
    East Texas
    Around 150 on the gauge both times.
    yep
    Yep x 2
    That's all it is that 30* temp swing is big to the engine. What was the temp the first time vs this time.
    I called my dyno guy after I had a fall off of rpm due to a 30* temp change a couple of years back. The 30* = 7.5% loss in power, in my case 50HP at the given rpm range.
    S CP
    East Texas
    Yep x 2
    S CP
    The air temp was probably in the low 60s first time compared to mid 90s this time. I've seen how much difference it causes at the dragstrip but that's comparing apples to oranges.
