experience with droop snoot/loader grate?
Results 1 to 14 of 26
    Senior Member nos1967's Avatar
    Default experience with droop snoot/loader grate?
    I would like to see what adding a droop snoot and or loader grate did for your boats performance, i already have a ride plate and set back pump...thinking of adding a droop and loader grate, maybe an inducer if it will really help. can i get some real numbers of top speed gains or max rpm changes from all you jet boaters. thanks a lot!
    Santa Clarita
    Droop is different on every boat....you will have to try it to see if it will work for you. If you are running over 70 a loader is a must.
    with a loose pump and 300 pounds of extra weight i was creeping up on 65mph before i let off, so im hoping after the pump rebuild and a few new modifications i can reach 70. and this is with a 340hp 454, after the pump is ready is rigged its engine time!
    500 hp 10:1 BBC
    Berkeley pump with American Turbine split bowl, American Turbine A impeller
    White Lightning half blocker loader
    Aggressor droop
    No shoe or ride plate
    The droop picked me up 3mph and the loader greatly improved midrange pull.
    At 5300 RPM boat tops out at 77mph
    460 is offline
    ATTA BOY 460's Avatar
    500 hp 10:1 BBC
    Aggressor droop
    insert ford comment here
    I wonder what a 500 10 to 1 ford will do. I can tell you a 425hp will get you to 5k at 76mph.
    Quote Originally Posted by Fo Sitty View Post
    5K @ 76mph just means the pump may be a little more efficient than my pump, or the boat it's in may be a little lighter than mine, hull tuning, etc etc. Nothing to do with the motor.
    Senior Member Futs's Avatar
    Orange CA, Big River
    C'mon, really? Im stay sayin......
    Senior Member PonyFiveO's Avatar
    Feb 2009
    Southbay to the Central Valley
    I am also curious about before and after results, specifically for an Eliminator Bubbledeck or a similar hull.
    I understand that results are different from boat to boat, even in same/similar hull designs. But if 99.9991% of those using the droop, in that style hull, have positive results, then I would feel better about spending the initial cash for the mod han for something that has positive results only 51% of the time.
    Thanks!
    Arcadia CA
    Talk to tom at Jet boat performance. I was wondering the same thing and he was straight up. He told me that with the size of my boat (20') a droop probably wouldnt be worth it. From the sound of things he's an expert on this shit and is very generous with his time and wisdom. hes an advertiser here.
    Senior Member CK7684's Avatar
    Minnesota
    I put on an SS loader and picked up 1mph. I also felt that I had better acceleration as well, but I had also just adjusted my valves so I'm not sure what to give credit to...
    have you trimmed it yet or did you just bolt it on?
    Senior Member tunabiteme's Avatar
    riverside
    Quote Originally Posted by PonyFiveO View Post
    Thanks!
    when my boat 1993 caribbean (boat in avatar)
    had the stock 330 hp BB chevy, worn out j/g berkley A cut imp with place diverter it went 52 mph. had mpd do the pump with a/b cut imp stage 1.5 blueprint, first test with fresh pump 59mph. then we added a place droop 61mph, next was a place bolt on ride plate 62mph all the test runs were made back to back parts were changed on the ramp. my conclusion is for my boat droop was worth 2mph ride plate 1mph. hope this helps.
    CODE8 code8's Avatar
    CHULA VISTA
    My personal experience. My boat is a heavy 21 Ultra Stealth with a stock SBC 350 hp. With nothing done to the boat it went 52-53 MPH with a full load. I put a loader grate,droop snoot and a ride plate it now goes 55-56 mph with a full load. The fastest I had the boat was 57.8 mph. That was just me in it no load and 1/2 tank of gas. All my speed was recorded on my hand GPS. I believe it helped out my boat but again all boats are different. Just my two cents.
    Minnesota
    I just bolted it on...should I trim it? I know I might gain some if it's "tuned" but I'm not sure how to go about it, or if it would be worth it seeing as I'm not racing...
