Fuel Supply Question - Just Curious
Results 1 to 8 of 8
    Member dopeyest1's Avatar
    Idaho Falls, ID
    Default Fuel Supply Question - Just Curious
    Just wondering if there was some reason why the fuel junction where both my lines from fuel tanks come together only allows fuel delivery from 1 tank at a time. Is there any kind of reason a person couldn't just use a T that draws off both tanks at same time? I'm getting old and lazy and see no reason to have to crawl to the back of my boat and burn myself on the headers switching the tanks over. (balance ain't what it used to be after a couple "tall boys"
    If it's petty, don't sweat it - If it's sweaty, don't pet it
    Senior Member tahitijet's Avatar
    the 2 reasons i draw mine seperatly are so i can use 1 kind of like a reserve. when i run out on 1 i know it's time to turn back. and if something goes wrong with 1 side and picks up an air leak you still can draw off the 2nd.
    Quote Originally Posted by tahitijet View Post
    x2 good advise!
    Massachusetts
    Talking
    I guess that fuel would flow from the higher tank to the lower one and maybe flood out through the filler line. Then air would get into the hose of the emptier tank and air-lock the fuel delivery if you are running a suction pump. not so bad if they are side tanks. Get a big fire extinguisher and a fire suit and try it.
    Idaho Falls, ID
    Thanks - makes sense - Firm beleiver in "if it ain't broke, don't fix it". Like I said - was just curious Hope the old lady don't bitch too loud when she burns herself!
    Senior Member 76Elim's Avatar
    Apr 2009
    The 73 Sleek my dad owned and now my bro owns had a 3 position valve that could feed off of both tanks or each seperately. When my bro restored the boat he needed a new one but searched everywhere and never found one that would allow you to feed off both tanks so now it has the typical 2 position. From my recollection it worked fine feeding off both tanks, however it would end up burning more fuel out of one of the tanks. No probs with fuel delivery though. My Eliminator has the 2 position and I have always thought it would be nice to feed off both tanks to keep the weight distributed more evenly.
    Santa Clarita
    They make valves that allow you to select Left, Right or Both. Pick one up and swap it out. The cheap brass valves only allow left or right tank.
    http://www.cpperformance.com/detail.aspx?ID=842
    IF you tee it off right in the middle.You can run off both tanks.They will drain even. If you have a fuel gage in the tanks you will be able to read the level. If not use a flag stick. Ran off both tanks for years not a problem!!
