1 Wire Alternator
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 48
1 Wire Alternator
    Member dopeyest1's Avatar
    Idaho Falls, ID
    Default 1 Wire Alternator
    Can someone please draw me up a wiring diagram for a 1 wire alternator setup. Looking at how mine is wired and it just doesn't make sense. It's for an Olds 455 Thanks
    If it's petty, don't sweat it - If it's sweaty, don't pet it
    + on the battery ---------------------to the terminal on the back of the alt. easy peasy, 1 wire
    I'm baaaaack... hkunz's Avatar
    Lake Havasu
    What he said
    It is impossible to defeat an ignorant man in argument. -William G. McAdoo, lawyer and politician (1863-1941)
    07 Advantage X-Flight 600 SCi Bravo 1 XR
    04 Cheetah Scorpion 6.2 Bravo 1 - SOLD!
    96 Donzi 21' 454 Bravo 3 Medallion - gone!
    72 Tahiti 16' 468 Olds Berkeley jet - SOLD!
    11 RZR XP, 08 Polaris Scrambler, 06 Rhino, 06 Joyner 650 dune buggy, 04 KFX 700
    Idaho Falls, ID
    Thanks - that's what I thought - I wonder where the 2 wires hooked up to it go LOL logs coming off tomorrow and OT's going on so the semi-wad of wiring will be easy to get to and redo. Thanks
    Idaho Falls, ID
    OK here's what I think I have determined from this mess. Well, I guess it isn't a "real" bad mess - hard part is I am sure I'm working with the 1975 wiring and some of it is faded enough that it's hard to tell blue from black, yellow from white, etc.
    ANYWAYS - the diagram that came with my new alternator shows the wire already discussed (post to pos. terminal) Then there are 2 side terminal wires and directions state:
    Terminal 1 must receive voltage. This voltage is provided by the indicator lamp on most "vehicles". However vehicles that have gauges will use a resistor in place of the indicator lamp. (there is an exsisting wire that runs from the amp gauge in the dash to very close to alternator so I am persuming that is wire #1
    Terminal 2 must have battery voltage. This voltage is supplied directly from the battery and will be present whether ignition switch is in the "ON" or "OFF" position. (there is a wire that runs from the post on back of ignition switch labeled "Batt" and it runs fairly close to alternator also.
    I'm thinking and hoping that these are the correct 2 wires. There is a heavy wire (10 guage) that was one of the wires hooked to the old dinasaur alternator that lookes like it came off one off the starter posts. (hard to see - still have logs on - don't want to pull them yet in case UPS doesn't show tomorrow on there scheduled delivery day - party time weekend!!)
    Well if this sounds right or wrong I am sure someone is a wiring wiz on the boards and I hope they can point me in right direction.
    You are making this more difficult than it needs to be.
    1.)Disconnect battery
    2.)Remove old alternator and install new one.
    3.)Connect output wire(the larger of the three) to the output post of new alternator.
    4.)Remove the other two wires. They are no longer used. This is real simple if you have a terminal block on the engine. If no terminal block, insulate the wire ends and fold wires back into harness(unless you WANT to follow them all the way back to source).
    5.) Reconnect battery
    Since you have an amp gauge, the output of the alt goes all the way to the gauge and then back to the engine and then back to the battery. With a voltmeter, it would not run to dash but would take a more direct path to battery.
    Idaho Falls, ID
    So you're saying that signal will already be route to guage then and just ignore these other to post? hmmm Let me finish what directions said about each terminal if it isn't hooked up (did a little abbreviating on last post):
    For terminal #1: "Failure to have voltage at terminal #1 may cuase:
    No charge, Indicator lamp off.
    Charges OK, but indicator lamp is on.
    Will not charge unless engine is "revved" up. Indicator lamp may come on when unit begins charging.
    For terminal #2: Failure to have voltage at this terminal will cause:
    Sorry if I sound a bit nervous - had battery die on the lake the other day and took 1 1/2 hours to get a jump. Hopefully I am overkilling here - just want to do it right the 1st time
    Are those directions from the NEW alternator? Is it truly a one-wire unit? What brand and model?
    And how about some pics of the old and new units.
    Idaho Falls, ID
    The new one is a Delco Remy #20038 The old one is an old Motorola Transpro 5-197 Give me a sec and i'll snap a couple quick pics (have to figure out new digital camera - the little woman dropped my old one a couple weeks ago and it is now taking pictures of the bottom of Palasades Resevior.
    Quote Originally Posted by dopeyest1 View Post
    Hook it up as I said above. Test its operation. You --may-- need to blip the throttle to start it charging.
    Idaho Falls, ID
    1st 2 are the old Motorola
    this is the only decent one of the Delco - hard to get mounted in boat but tried to show the other plug I have been referring too.
    Hope these work 1st time posting pics here...
    1 boat's never enough Bigtorq's Avatar
    The OC
    Hook it up the way old squirt described and you'll be fine. Terminal 1 is for an idiot light to tell you when it's not charging (you have a guage for that). Terminal 2 is used for sampling voltage at a terminal strip on a car so that the alternator will charge the battery and make sure you maintain about 14V at the terminal. For a boat you don't need to worry about this because of the short distances and lack of nav systems, dvd, head lights etc . . . Just hook it up and put a voltage meter across your battery terminals when it's running. Verify >14V and you're good to go. Good luck!
    Nov 2009
    Default sanger flat
    looking for deck mount tach for castle v drive also bassetts or glenwood water log for a 440 ot only
    Denton, TX
    Quote Originally Posted by Mark Walker View Post
    Really?
