death of a motor
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 108
death of a motor
    Member pushingvws's Avatar
    auburn, ca
    Default death of a motor
    I know I'm not supposed to start it on the trailer so shoot me. I know my motor is shot, but can someone please explain the God awful amount of white smoke and how that happens?
    Fleetimus, it looks like you don't need to come over tomorrow to look at the motor, seems I'll be needing a new one.
    Anybody got a motor in nor cal for cheap?
    Thanks,
    Nick
    Senior Member revndave's Avatar
    Indio,CA.
    Quote Originally Posted by pushingvws View Post
    Thanks,
    Nick
    I've started mine on the trailer with no problems.Are you sure its shot???
    auburn, ca
    Quote Originally Posted by revndave View Post
    last I checked, billowing white smoke from a motor wasn't very good...i may be wrong, infact I hope I am... but it seems like that means something pretty major is wrong.
    ideas?
    Indio,CA.
    Have you tried to start it again?
    Indio,CA.
    Give it a pump of gas and go for it.
    Are you sure it wasn't steam from the headers? If not that, you may have just blown a head gasket. An afternoon later and a gasket set and you are back in business. Fleet could probably set you strait.
    Cy
    auburn, ca
    I started it twice, both with smoke billowing out... I'll need a second opinion before I start it again....
    maybe tomorrow
    auburn, ca
    It was def smoke not steam. Choking, eye's watering smoke... seemed to come from under the engine and out the back, exhaust pipes too
    Cy
    Indio,CA.
    Sounds like a head gasket.Any water in the oil(milk shake)?
    auburn, ca
    no, I just changed the oil too. There was oil spray on the side of the motor though.. does start to sound like a head gasket.
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    Head gasket.....don't start it again. What did the oil look like when you drained it?
    auburn, ca
    Quote Originally Posted by RaceFace View Post
    looked fine. looked like used oil.. maybe a slight hint of grey
    Woodstock, IL.
    That's a bummer not the way to start a big weekend.
    That could be the valve guides allowing the il to get into the cylinders and look like that. It didn't sound lie there was any knocking and that is a good thing. it couls be a simple as a valve job.
    Cy
