ok guys I got one for yall,
I got a 1973 Wriedt with a 460 BB in it, and i was runing wide open accross the lake bout 7am when the water was like glass, and then all of a sudden the engine ran hot and shut down on me, it wouldnt even turn over so i let it set for bout 45 minutes to let it air cool then hooked my bilge pump to it and run water through the engine to get it cool, fired it up drove it back to dock, brought it home and did a compression check one side of engine (all 4 cylinders) is runing 125 lbs of compression, the other side 1 cylinder 75 lbs other 3 cylinders 55 lbs, no water in oil and spark plugs are clean (no oil on them) so is it a head problem? or a cylinder problem? if it was a cylinder wouldnt my plugs have oil on them? and if it was a head problem wouldnt I have water in my oil?
any help would be greatfull
