Disturbing noise
Results 1 to 14 of 27
Disturbing noise
    Default Disturbing noise
    The chances of me explaining the noise accurately are prolly slim but here goes.... Fired her up on the trailer at the ramp today, and here this very audible squeal or maybe screech. Anyone in there right mind would probably pull the boat back out....so I went boating. I can imagine nothing that could make the motor sound like that other than possibly an alternator, kinda thinking it's in the pump. Squeaked/screeched all the way out the idle zone...after a minute or so of running easy, I let off and it went away at idle. When I got back into it it came back at higher r's for a minute or so the disappeared completely. Any thoughts....the only thing I've done since the last time out is put on a new alt. belt, and pulled the bowl off the jet to try to figure out why I was getting no flow to the motor at idle. Sorry for the long read..
    squeeling could very well be an alternator belt.
    Morgan Hill
    Starter hanging up?
    GT
    GT
    Silverdale, Washington
    Starter hanging up?
    GT
    X2 on what Cy and Glenn said.
    If it stayed I would look for a vacuum leak to as I had a big issue with my manifold and thought of all sorts of bad things only to find the manifold had an issue.
    seattle
    sounds like impeller to wear ring clearance, i would inspect the wear ring, and check tolerances!
    hope it was just a belt, but you should take a look see!!
    Well hopefully it's gone(yeh right). It wasn't a loose alt belt,last time out I tossed one(apparently outta the boat) about 30 minutes into the day. So the replacement went on good and tight. My 1st thought was, crap did I get that belt on a little too tight. My 13 year old noticed it asap, but I'm not sure if it was distinct enough/(or loud enough) for everyone to hear,wifey didn't hear it from the drivers seat.
    Bullhead city AZ
    Sound anything like this....................loooose alt belt
    Don't ask
    Dallas, TX
    Since you just changed the alt belt right before the squealing started, I'd be suspect of the belt tension. If nothing else start it up and see if it is squealing again. If it is, kill it remove the belt and see if the squeal is gone.
    Quote Originally Posted by 2savage4you View Post
    Don't ask
    That was a little odd sounding for a belt.lol I shouldn't have said it sounded like an alternator, but my 1st thought was oh crap I put that belt on so tight It's taking out all the bearings inside of it. I just checked the belt it's about right. When it blows all the way up I'll let you all know what it was. Oh and the wife couldn't hear it from the drivers seat of the durango. She's so f'n paranoid I couldn't ask her for the camera to record it ...or she would have never got in the boat.
    Sep 2008
    Rancho Cucamonger, CA
    ...the only thing I've done since the last time out is put on a new alt. belt...
    Quote Originally Posted by 1975sleekcraft View Post
    Maybe I picked up some caca on the way to the lake??? I dunno...It wasn't purdy whatever it was. Kinda sounded like a v-drive with a problem, I'll never be able to put it into words.
    Charlotte, NC.
    pull the belt and run it. See if it goes away. you can run on battery for a little while no issues. Saying it sounded like it was in the pump is scary though.I would check my impeller and wear ring.
    Senior Member wolfie's Avatar
    Hope everything works out for you. Hope it's just the belt.
    Mine ran well today. I think I'm giving up so HP somewhere though. Maybe need a little carb adjustment. Maybe some valve adjustment. The main thing is that it started and ran all day today.
    Must have missed you today. We stayed just outside of Provo marina area and did some tubing, skiing and just floating.
    We'll need to meet up with TBI next weekend up at Echo.
    sounds like the bearing in your pump! i just had the same sounding problem i thought it was my motor also but that was not the case.
