Hydraulic Diverter Conversion
Results 1 to 9 of 9
    Default Hydraulic Diverter Conversion
    Has anyone ever converted a manual diverter to hydraulic? I know CP sells the conversion kits. How hard is it to do?
    Also, I know you have to run a trim gauge to tell you where your diverter is positioned. What actuates these/makes these work? Is there a sender or is there some sort of mechanical linkage to the gauge?
    Member BadBahner's Avatar
    Apr 2009
    There is actually both. Mine has a mechanical cable that is attached to the diverter. As the diverter is moved up and down it moves the cable which in turn moves a small arm on the sender mounted to the inside of the transom. The sender then has wires that go to the gauge.
    BadBahner
    1981 Bahner 19 Bubbledeck 454 12jg
    2009 HTM SR-24
    [QUOTE=Jetaholic;734296]Has anyone ever converted a manual diverter to hydraulic? I know CP sells the conversion kits. How hard is it to do?
    easy conversion, remove the manual cable and thru bore that hole for 1/4-20 bolt, this retains the hyd cyclinder. mount pump and wiring, not a difficult job, one could also purchase the oem hyd arm for a bolt on install.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Pictures
    Must have pictures!
Name:	'08 boat pictures 001.jpg
ID:	46837   Click image for larger version.
Name:	'08 boat pictures 018.jpg
ID:	46839   Click image for larger version.
Name:	'08 boat pictures 020.jpg
    Loose, the Dogs of War!
    Thanks for the pics Mark!
    Is there anyone with the installation instructions for a hydraulic diverter that can scan them and post them up for download?
    Member Rogers daycruiser fan's Avatar
    Orange County,CA
    I have my copy I got from "Place Diverter when I did mine, but no scanner working here. send me a pm with a fax number and I can send it to you
    Santa Clarita
    The kit comes with full instructions.
    Denton, TX
    Is it really as responsive as they say it is or is it like and inboard/outboard deal?
    I like my handle but it can be a PITA some times and im already making a list for winter.
    Quote Originally Posted by Btnhtillidie View Post
    I like the handle as well, however I had a brand new cable break on me this last weekend and posed a safety hazard which involved some friends of mine on another boat getting hosed down (the nozzle is free to do whatever it wants when the cable breaks). This is why I've decided to go hydraulic. At least if a pump or an actuator fails the nozzle will stay put.
