Gull Wing jets
Results 1 to 14 of 42
Gull Wing jets
    Under yo mommas bed jangles's Avatar
    Marana, Az
    Default Gull Wing jets
    Are these bottom fast? Just saying. ???????????//.....
    "Thanking Obama for killing Bin Laden is like thanking Ronald McDonald for the hamburger.
    Thank the SEALS NOT the CLOWN.
    Official Member IttyBittyTittyCommitee
    http://newsbusters.org/
    Yucaipa Ca
    They are very nice hull, have a friend and his is in the triple digits. It would be my choice, there fast hulls, and still river friendly.
    i'm back!! 1QuickCP's Avatar
    Montana
    if a light hull and rigged and setup correct....oh yeah there fast...in a lake weight hull a 19 will run a tad over 100 with about 900-1000 hp..stable as a rock..lol.ur results may vary.... but they start to get a bit "interesting" at over 120...
    **Btw I run at 4500 ft so faster at normal elevations, I have rigged and set up maybe 10-12 18's, 19's and CP tunnels
    Default lees power
    you can get to 100 with 650 hp easy enough
    Marana, Az
    Well thanks for the replies but I decided to keep my old boat.
    Senior Member SLACKER's Avatar
    Glen Allen, VA
    Quote Originally Posted by OkieDave View Post
    I would have to agree on this
    Is there many 18' hulls out there? I have one and seems like all the ones I run into are 19'?
    So Cal
    Quote Originally Posted by chevy1956 View Post
    I have an 18, there are lots of 18's out there
    Quote Originally Posted by SLACKER View Post
    There sure aren't many of those running around. The only CP GW I've ever seen run 100 with even anything close to only 650 hp was Segni's (Blue Bomber) Built 468 maybe 675 hp it ran 105 off the Nos. Light boat less than 550 lbs and don't even think about walking across the bow.
    There are a few guy here that know the boat I think Ron won 6 Championships with it? It was dialed in and he had a shit load of time in it to do it. I'd like to see a 19' GW "Lake" boat run 100 with 650 HP. Not saying it can't be done but knowing what Segni did to get his to do what he did I don't see Joe Blow making it happen.
    Sleeper CP
    Senior Member Bobsnipper110's Avatar
    Sleeper CP
    Doesn't any one ever keep track of records? I m not Joe blow, but my 18' cp 460" chevrolet still holds the ski jet record (sorry Ron Segni) and the comp jet record, both et and mph. Best pass 8.64 et at 121 mph. Hope this sets the record straight.
    Quote Originally Posted by Bobsnipper110 View Post
    I don't recall mentioning any records And a racer of your caliber is certainly no "Joe Blow".
    Curious, how common would it be for Joe Blow river racer to build a 650 hp 100 mph Jet ?(regardless of GW or not) from my experience not very common.
    Have to talk later I'm headed to a meeting
    S CP
    Montana
    well ill put my 2 cents in...full weight cp19, motor dynoed at 967...at 8000 ft (101 deg out) relative altitude it ran 101-102 on gps and stalker 2 radar set up and dialed in
    cp 18..bottom done mid weight hull full interior, 850 hp on the dyno, 96 mph same conditions
    we would gain about 4-6 mph at parker as opposed to r test lake.
    not saying it cant be done but I think it would be very hard pressed for a full lake weight 19 to run 100 with 650 hp....we did a super light 18 (potato chip) with about 700 and it ran low 90's at altitude,still had 2 tanks and interior.
    any way thats just what i have seen
    Colfax, Ca
    My TX-19 Condor runs 92 without NOS. (NOS is there, 100 on each carb), 520 lbs hull with intake, gauges and steering. 468 BBC,12.8-1 comp, Merlin 345 heads, 715 lift, solid roller, tunnel ram, 850 DP. Dominator housing, AMT Bowl, Aggressor Bronze "B" imp, 2* back cut shoe, 3.5* ride plate. Engine has never been dyno'd.
    I have done nothing as far as set-up since it went back together. I feel I have a lot to gain with some set-up work. I want the "Bitch" to be quick, not a lot faster. Any suggestions??
    So Cal
    I'll take you for a ride in one once I get it rigged.
    Sincerely,
    Joe Blow
