berkeley pump question
Results 1 to 8 of 8
    Senior Member tx19condor's Avatar
    Default berkeley pump question
    I have a jc pump in my boat, it is at my buddys place right now getting rebuilt and I wont have it back until next week. I have alot of other work to do such as finishing up the rail mounts. I borrowed a jg pump from my cousin for mock up to locate the motor and drill the holes. Are the jc and jg housings similar enough to do that or should I just wait until I get mine back? thanks.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    the only difference between the 2 is the bowl. The C bowl is a 1 piece unit whereas the G is a 2 piece. Here are a couple of pictures so you can see the difference.
    JG-
    JC-
    (pictures were taken from the CP Performance website)
    Here's the link to CP Performance's Jet Drive page-
    http://www.cpperformance.com/product...es/default.htm
    thanks. evidently the suction housing is the same, mine has the split bowl on it like the jg in the picture, but it definitely says jc on the tag. thanks for the info
    Cas
    Cas is offline
    Quote Originally Posted by tx19condor View Post
    There are many C bowl pumps out there where people have changed to the G bowl. The G bowl just gives you more options on what to do with the pump ie: droops, snoots, wedges.
    B1 Racing cs19's Avatar
    I would be using the one you plan on running in the boat
    B1Racing.net
    Senior Member TrollerDave's Avatar
    Chino,CA
    Why?
    Not to doubt you, just trying to understand. Aren't the bowls the same up to
    where the JG 's nozzle or droop bolt on?
    The suction housings, don't have an absolute standard for bolt pattern, or let me rephrase that, if you want perfect alignment use the one you want to run. The holes can vari, as much a 1/4 hole, from housing to housing.
    Default set up
    Excellent advice Tom
