Pressure valve
Results 1 to 14 of 28
Pressure valve
    Southwest corner AR
    Default Pressure valve
    I have a Watts pressure valve on my inlet side from the pump to motor. Where would the best place be to gauge the pressure from the valve or the thermostat housing or?
    The Right Coast/SE-PA
    I have my pressure gauge in the port right next to the thermostate housing, seemed like a good place to me.
    Ladera Ranch
    I've got a thermostat block off plate(easy to make) and drilled & tapped for the 1/8th NPT:-4 fitting. Works bitchen.
    Southwest corner AR
    Do you run a gauge all the time or just to check pressure!
    TJS
    TJS is offline
    CT
    I have a block off plate as well. To me it seemed kind of thin and my gauge uses a 1/4 NPT. I made an alum. 1/4 NPT "bung" and welded it on from the back side. The gauge is always there. I set my watts so I see about 14 psi on the gauge at WOT.
    T.J.
    Here is a pic.
    I run the Rex Marine Thermostat (bypass system) for years now and it works GREAT! So there is a thermostat in the special housing. I keep the water pressure guage right mounted next to it on a port in the intake mamafold. I never see any readings less than 8 psi or more than 12 psi > perfect!
    Senior Member JetBoatCop's Avatar
    Elgin, TX
    Where can you get the Watts valve, and does it go inline on the hose coming from the pump? Also, is there still a lot of volume?
    '78 Taylor SS 460 BBF, Under Construction
    '03 Glastron SF 185 18', 4.3 Volvo Penta
    '95 Dodge Cummins 3500 4x4 Single Cab, Dually, Triple Gauges, and some pump work!
    Southwest corner AR
    Quote Originally Posted by JetBoatCop View Post
    If you are running log manifolds you don't need one. The watts valve can be bought at a plumbing supply or a pump supply source. It is mainly used for regulating water for homes and industrial apps. The pressure coming in is regulated to a set point from 15# to 75#. I think that you are building a Taylor SS and a ball valve on the JE pump pipe before the hose will work fine and cheaper! IMO. I will get the part no. if you need one!
    Elgin, TX
    Ok, I have the ball valve. Do the logs dissapate the pressure? I was just worried about blowin through head gaskets.
    Ladera Ranch
    my gauge is full tie in the dash. Hi Compression pump gas. Water pressure plays a critical role in fighting detonation. WOT Im seeing 23 lbs pressure, water temp is around 130 or so.
    Southwest corner AR
    All good info. guys first time with this setup just learning the ropes!!
    Default watts valve
    I installed watts valves on two different boats[jets]. Both malfunctioned,And yes ikept the screen clean. ......i recomend a pressure bypass valve set to blow extra water out the transom. Htp sells them with a install kit but I didn't like the install kit. Somebody on here can probably give you the part # and you can pick it up locally.
    MI
    TSC sells this nice aluminum one.
    Ladera Ranch
    pay attention, take the screen out!
