My BBC leaks way too much oil! Every time I run it I get oil spray all over the back of the motor and bilge within a few mins. Its a huge mess.
It looks like its coming from between the head and block on the driver side rear of the motor. The heads are torqued properly and no water in the oil.
Is that common to be leaking from the head gasket?
Its not coming from the pan, rear mainseal or valve covers. I dont think its coming from under the manifold but its hard to tell because there is so much oil sprayed all over the place. From the looks of it, it just seems to be leaking from all around the rear of the head gaskets on the drivers side.
Im wondering if I should try to just replace the manifold gaskets or go ahead and do the head gaskets at the same time?
My BBF does the same thing. I was told that it is coming from my valve cover breathers. Is yours doing the same ? Last time out so much oil it fouled my bilge pump. My fix is going to replace breathers with new vented with a line to carb to burn off leaking oil. I am very new to this so a frind is going to direct me as to what to do, no exp. so I will give it a try and see if it clears up my problem....I do need a new bilge pump as well
could be breathers but more thatn likely id say it was your manifold. are you using gaskets on the front and rear? if so, ditch em and run about a quarter inch of black high temp rtv insted of using gaskets. never heard of oil leaking from a head gasket. id venture to say if it was that severly blown youd have water in the oil unless its blown in just the right spot.
if your gonna pull the manifold its really not that much more work to pull the head except for having to run the valves again. like i said, imo i highly boubt its your head gasket. do a leak down and if everything checks out on that id say pull the manifold and re-seal it,. dont forget to replace the manifold to head gaskets as well. throw er back together and get er back on the water!!!devil
Just so you know, these guys are NOT saying ditch your intake manifold gaskets and replace them with RTV. They are talking about the gasket on the horizonal rail that goes between the block (not HEAD) and manifold. drag your finger around the block in that area and see if there's oil, if it's that high then thats probably where your leaking.
Yeah there are no cork gaskets used Just Silicone sealing off both ends. I Think I might just go ahead and try to replace those first. Only about four trips on these gaskets and silicone job.
Not coming from the breathers either. I have been trying to track this leak down and it looks like its coming from between the head and block on the #7 Cylinder.
I should probably disconnect the driveline and run her on the hose in the garage for a while to see if I can find the leak first.
This is a fresh motor.
I realize its kind of hard to find a leak just from my description in this post. Im wondering if it is really uncommon to have a head gasket leak? If so I would lean towards the manifold leaking more and not worry about the head gaskets.
Alright I'll admitt I'm a tool junkie But , good money spent here is for and IR lite and florescent dye test kit Just had an illusive oil leak and this device "nailed it" In this case it was the cam plug (needed to be "pressurized") It should tell you exactly where and how the oil is "getting out" ! Tom
Simply an outside observation if you are not evacuating crankcase pressure in one way or another, you will have leaks somewhere for sure. We've remedied an awful lot of them over the years by only addressing crankcase vacuum.
If this is a pressure fed gallery leak, you'll have to hunt it down and fix it. The aforementioned remedy will do nothing for that.
Frank I had a leak in the same spot your typing about. It was my Oil Pressure gauge connection to the block. I didn't put any teflon tape on it and it was leaking pretty good. It was tight but not tight enough. The Spot I'm speaking of is right above the Oil Filter. There is either a plug or your sending unit if its electric. Jus sayin it might be the location. Hope its that easy
I ran the Boat in the garage on the hose for about ten minutes and found my oil leaks. It was draining out of the rear main seal. I also heard a seeping noise and a small amount of oil coming out of the silicone on my manifold after I shut the motor off.
The motor has breathers but you could tell there was pressure in the crankcase with the noise and oil coming out of the manifold.
I ran the Motor without the breathers and not a drop of oil out of the mainseal or manifold.
Turns out these beathers are just lousy by design. With the caps tightened down on the breathers it smashes the rubber grommets and allows no air through.
I threw some small washers under the breather caps. Problem solveddevil
Heres the pics. Notice the oil on the pump intake. This was after five mins of idleing. Also you can see the breather caps and where they were sitting on top of the rubber grommets.
Thanks guys for all the help and suggestions I appreciate it!
i made some passes this last weekend on the river in yuma, and saw that i was leaking oil but could not find the leak. then made some more passes and found out it was the front main seal and while spinning the motor up to high rpms it sprayed every where. time to pull it apart and fix it.
Related Threads
Performance Boats Forum
2.1M posts
41.1K members
Since 2007
