setback pump transom plate template
Results 1 to 14 of 27
    Senior Member tx19condor's Avatar
    Default setback pump transom plate template
    I just finished making a template for a transom plate. My pump isnt set back real far, the hand hole cover is about 3/4 of the way outside the back of the transom. The boat is a condor tx19 with a berkeley pump. I scanned the template in to my computer and if it would help anyone elso out I would be glad to email it to you. If nothing else maybe it would give you a starting point if you need to make one. Now I need to decide if I should make it out of dark lexan or aluminum. I was going to use 1/4 inch dark lexan, since im not the kind of guy to polish aluminum all the time and keep it looking good. What do you guys think? Send me a pm with your email if the template will help you out.
    Glendale Arizona
    Quote Originally Posted by tx19condor View Post
    PM sent.
    I'd be worried about the lexan breaking/cracking.
    pm sent i would use aluminum, that is what i used om my liberator , i [polished it then sprayed clear over it , and never has a problem.
    emails sent to busby, taylorman and squirtcha. let me know if they dont come thru ok.
    ive got a hunk of fiberglass I could cut them out of too. maybe that would be better than lexan and easier than aluminum
    Ladera Ranch
    aluminum isn't that hard to cut...
    I have kicked around the Idea of fiberglass also.
    If I gel coated it white it would blend in better.
    Glendale Arizona
    Got it................thanks
    Brendellajet is right. I use a regular old circular saw with a plywood blade flipped around backwards for straight cuts and a jigsaw with a metal blade for the other.
    It's really not bad to work with. The 1/4" is easy to cut. Not sure what the next size/thickness down is in aluminum plate but that would be even easier and probably plenty strong.
    I've even cut 3/8" plate with my circular and it buzzed right through it. It helps to have someone spray the blade with WD40 while you cut. It keeps the aluminum from melting and sticking to the teeth.
    Senior Member cave's Avatar
    Mesa, AZ
    Aluminum will cut with a crosscut carbide tooth saw blade. I used to do it all the time. Freaking chips hurt bad so wear eye protection!
    Im going to go with aluminum. I think the fiberglass or lexan will crack from the stress of the steering cable and place divertor cable pushing and pulling against it. now I just need to score a piece of plate somewhere.
    not to worry, I wear my safety contact lenses everyday!
    Default clamshells
    Interesting concept and virtually unbreakable too! ,We've use both aluminum and fiberglass ,here's one from this week and a couple prior as well Tom cool never thought about Lexan ,??
    not sure where you live, but sometimes where I live
    aluminum products are hard to come by.
    this is where I purchased my angle for my rails.
    http://www.metalsdepot.com/index.phtml
    Senior Member superdave013's Avatar
    you guys need a Busby. lol
