this sucks! HELP! FIXING IT THE RIGHT WAY!
Results 1 to 14 of 30
    Senior Member 1975DiMarco490ci's Avatar
    Glendale (AZ)
    Thumbs down this sucks! HELP! FIXING IT THE RIGHT WAY!
    So my first boat turned bad when i found the floor was bad. Well my new one....
    so how do you fix a floor on a full stringer boat... THE RIGHT WAY NOT JUST PATCHING IT! ALSO my driver side stringer is K.I.A had a knot on both sides and it was now looks like this
    how do i fix this???? PLEASE DONT SAY REPLACES THE STRINGER...
    lets start with these two problems
    WILL KILL FOR A GULLWING.
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Quote Originally Posted by 1975DiMarco490ci View Post
    OK I won't say ( REPLACE THE STRINGERS),,, You have alot of work ahead of you!
    Senior Member hotbo's Avatar
    lake Ouachita AR
    wow that sucks sorrybest thing to do is check the rest of the stringer strength and go from there.if they are okay you can patch the bad spots,or atleast i could.good luck.
    Glendale (AZ)
    tell me about it..... that is the only thing wrong with the stringers.
    Glendale (AZ)
    glad i have so much $ into this bs.
    El Cajon, CA.
    Where in the boat are the knots/cracks, I understand they're in the stringers, but where in the stringers?
    Senior Member GRoper's Avatar
    expensive hobby! i found out my floor was bad when my foot peddal screws ripped out doin 70 down the river. stringers seem fine though so i patched her up and will get to the floor issue when i have the cash. those stringers look shot!!! that sux man. I hope you can get her hashed out and on the water soon!!
    Glendale (AZ)
    just infront of the driver seat... say 6 inches
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    That's not a knot at all. At one time your boat was set up with the forward/reverse lever in the stringer, ahead of the driver's seat.
    My old Miller was set up the same way.....shady. They simply cored out a big ass hole so that the 'morse' escutcheon would countersink into the stringer, thus making the shift lever shaft long enough.
Name:	cored out stringer.jpg
    El Cajon, CA.
    I would repair the stringer and replace the floor if it were mine.
    I'm sure this will get me another internet beating but...
    Cut the old floor out, I used a circular saw with a carefull eye on the blade depth to get the majority of the floor out, I then used a grinder (with cut off and grinding wheels) and a wood chisel and a hammer to finish clearing out the old wood and glass, I got some marine grade plywood and cut it to size, covered the plywood with resin, cut the plywood piece need for the back of the floor near the front of the engine and resined it, put the plywood in place, using cloth and resin glassed in the outer few inches of the entire floor and all over the piece in the back under the floor near the front of the engine, the process took a little over a 1/2 of a day. Good luck.
    El Cajon, CA.
    nice
    Glendale (AZ)
    nice
    so fill it with fiberglass?
    Senior Member Rain Maker MN's Avatar
    You need to replace the stringer to do it correctly....or at least replace a few feet of the stringer.......How much do you like the hull?
    Floor and stringer is a lot of work if the hull is not that great to start with
    Stringer time....not so bad if you don't have pretty balsa floors.
