Loader......
Results 1 to 14 of 34
Loader......
    Kingman/Golden Vly, Az
    Default Loader......
    i would like to see some pics of the loader set-up on ur boat...i'm thinking of putting 1 on mine & want to see what they look like in place
    TIA
    FastRat
    Junior Member 74miller's Avatar
    Logan, UT
    This one was in a 18' mantra with a 455 olds
    Logan, UT
    Here is another shot
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by 74miller View Post
    That thing has more blocker Than my R loader
    Does not look blocked.... more like an additional ramp, aimed lower.
    Really? So what exactlly is a blocker then? Doesnt it block the center portion inbetween the stingers? I know what your looking at, but that still will be considered a blocker even if it is ramped different would'nt it?
    Heres a pic of one of my loaders with 6" of blocker.
    lol, right..... Devilman's Avatar
    South Texas
    Looks like a good thread to throw this into:
    This loader is described as being "a Berkeley style top loader grate, a bit aggressive."
    What kind of application would it be good for? High HP, low HP, heavy boat, light boat, etc..... Or is loader performance even something that can be related to that way, with an off the shelf description based on a pic?
    Default Not gonna work!!
    TIA
    FastRat
    I am just trying to help on this!!! Without knowing the horse-power and pump work done, I will tell you that the ramp speed on the bottom to the grate is way to fast. As it is set on the photos I would almost bet that the boat will fight to get on top and the loader will make the boat either porpoise or dive into the nose, Again H/P and pump! That is a Southwind bottom splash and I have played with them alot. What is very important to that bottom design is in the loading to the bottom and that starts way before the intake grate! Lots of guys on this site will use different terminalogy for keel, chimes and hook! Not my problem. What I recommend is to lay at the transom of the boat and study the bottom. Then add in how you want the boat to ride. I have had three Southwinds (2 18ft v,s and one 19ft TD and never been happier with a hull. The last one was a 1976 18 ft v and ran over the 80mph mark with a very mild 429 ford. I also set the pump back 3 inches to assist in ride and attitude of the boat. M
    Heres a "cutaway" view and our loader
    460
    460 is offline
    ATTA BOY 460's Avatar
    Quote Originally Posted by Devilman View Post
    Kenny that is the same loader i have and it works good. I didnt lose any rpm when i added the one i have now. Im sure your boat will accept it and work good.
    Just the the fish a favor and dont spray it with the same flake as the boat. I dont think they can handle much more
    Feb 2009
    This one was in a 18' mantra with a 445 olds
    Looks like a GTH cast aluminum, low aiming loader from the era of 40 mph running starts at the line. With today's hammer-it-from-the-rope style a serious launch controller might be necessary (are those legal?)
    Circ
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I wish this was bigger.
    Wags
    My understanding of a blocker is, that it starts from the front and goes "X" inches back. The front on this one appears to be open, thats all. The loaders I have are like these (courtesy of MPD) I have an open, a V-blocker, and a partial blocker.
    Prune-Picker
    Calif
    Quote Originally Posted by Circular View Post
    How do you know that? Hear it from Tom, Jim, Duane, Jack, Joe??
    Cs
