Best way to clean steel air cleaners?
Results 1 to 8 of 8
    Massachusetts
    Default Best way to clean steel air cleaners?
    How do you guys clean steel aircleaners short of submerging them in a bucket of solvent?
Name:	Air Cleaner.jpg
    Take it off and shoot it with some brake cleaner.....
    Made In The Shade
    Custom Window Tinting
    as said .. Mineral spirits and Brake Kleen both work , then blow dry from the inside out
    Gumout Carb cleaner.
    And do make sure you pull it off to clean it.
    S CP
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Take it off...
    Put it in a three gallon pail and submerge it in Laquer thinner. Let it set, shake it around and then remove to blow dry, from the inside out.
    Loose, the Dogs of War!
    Massachusetts
    I used a can of brake clean and it worked great. I doubt the silicone sealer used on the upper and lower seams will tolerate that many times.
    Denton, TX
    I used to use LPS Pre-solve. That stuff is Great!
    x5 i like the gm brake cleaner, that stuff will take off paint
