Bilge pumps
Results 1 to 14 of 26
Bilge pumps
    Senior Member T-Train's Avatar
    Jul 2009
    Lebanon,Or
    Default Bilge pumps
    Here I go with another question. What type of bilge pumps are people using. I need a new one and what to here from other jet boaters. And are you running more than one? How many gph? Thanks
    Kingman/Golden Vly, Az
    there was a brand new 1 in the Parts for Sale forum, very reasonable!...i run just 1 bp & it works fine...no need for overkill!
    FastRat
    Cas
    Cas is offline
    Angry American Cas's Avatar
    I've got 2 800 GPH bilge pumps in mine. One of them has a float so it comes on automatically and the other is operated by a switch. I like the security of knowing I can leave the boat in overnight without an issue.
    The only thing I'd suggest is to get a pump with either an internal float switch or one with an electronic sensor. The float I have got stuck in the on position last weekend which could lead to a dead battery and a sunk boat.
    As far as the overkill comment, I'm going to disagree with that. I'm guessing you haven't had a big wave come over your transom or bow that puts a ton of water in your boat. I kind of like having 2 even if one of them rarely gets used.
    Senior Member tahitijet's Avatar
    agreed.. no such thing as overkill on bilge pumps. especially if you boat where alot of wake barges do. I take on a good amount of water just launching and floating at out local lakes. Personally i run 2 1000gph 1 on each side of the intake. but with my setback the water can't transfer side to side until it gets really deep and i hate having standing water in my boat.
    Silverdale, Washington
    I run one Rule 1000 on a float switch that's always hot and another Rule 1100 that is on a switch on the dash.
    Been happy so far (knock on wood). Good luck and see you at Mardon????
    Senior Member gregb's Avatar
    Redondo
    I've got 2 Rule 1000's. Empties the bilge pretty damn quick.
    Senior Member CoolCruzinCobra's Avatar
    San Dimas
    When I had the jet boat I ran two pumps .
    One with built in float always on ,the other one the switch.
    And for an over kill. I ran the extra which was on the switch on a different
    circuit . Just in case there was a short .
    07 razor
    Jul 2009
    Lebanon,Or
    I'm hoping to be there. I have been getting the boat ready. Just have to find a place to stay. We may come for the day and then find a hotel down the road. Can't wait.
    I have 2 Attwood 500 for the outside sponsons and
    a Attwood Sahara 750 automatic for the center
    #55
    Quote Originally Posted by T-Train View Post
    Moses Lake is not that far away. Fast straight country roads. I wouldnt lose sleep over it if you can't stay at Mardon (besides, you probably would lose sleep if you did! Iff'n you know what I mean.. )
    See you there...........john
    Massachusetts
    Here is a pic of my Rule 4000 GPH automatic pump. On the other side is a Rule 1000 GPH. I fish Lake Champlain which can toss 8 foot waves at you when the wind picks up. The 5000 total saved my boat last year when I swamped it near Plattsburgh, VT on the way in during a bass tournament.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default X2
    Both of mine are "switched", and one is on the float. I have check valves at the discharge of each pump to keep the flow from returning when not switched.
    AND I can no longer post pictures to this site so I can't show you. I can post the same pictures to other sites! Go figure. I contacted Mike, no help.
    Loose, the Dogs of War!
    Cas
    Cas is offline
    Quote Originally Posted by Schi-502 View Post
    can't you just upload them to photobucket and put them here? it's real easy.
    I'll give it a try.
    Thanks.
    Missed you last weekend. I was there in spirit.
