lets see some engine compartments
Results 1 to 14 of 24
    Aug 2009
    Default lets see some engine compartments
    restoring my jet looking for some ideas for the engine compartment
    spokane, WA
    What ideas are you looking for?
    Massachusetts
    Here is my Gator Jet Bass Boat engine compartment. Vortec 350, four M-30 batteries, Stealth on the fly charger, etc. The two large storage bins are removed so you can see the engine & battery areas. The bilge area needs cleaning! I made the pics large so you can look around.
ID:	50287   Click image for larger version.
ID:	50288   Click image for larger version.
    Aug 2009
    looking for ways to mount alternator and have a very clean engine
    spokane, WA
    I hear ya on make it clean man, this may not be what you are looking for but here is my set up, not one wire showes.
ID:	50303   Click image for larger version.
    Aug 2009
    thats a sick engine bay man
    San Francisco Bay Area
    Cool
    LO
    High Flow Dynamics
    Heres a few of ours ...
    Colfax, Ca
    Shell Knob, MO
    Member Pig Pen's Avatar
    Jul 2009
    Sep 2008
    Is that an all aluminum LS3 motor? If so, can you please let me know the following:
    • How did you set up the fuel return to the tank
    • How did you set up the O2 sensor on your exhaust or are you doing away with O2 sensor all-together
    • Are you running a T-Stat and if not, how are you regulating the water temp since these engines (I'd assume) like to run under constant temp rather than it being fluctuated like on a normal jet application
    • How does it perform for a jet application, i.e., max speed, hole shot, etc.
    Thanx in advance...
    Quote Originally Posted by Pig Pen View Post
    Yucaipa Ca
    It's an LSX.....
    Member twowheeledfish's Avatar
    I can't take credit for the rigging, but its pretty clean!
