oil
Results 1 to 14 of 95
oil
    Senior Member bc18's Avatar
    Default oil
    what type of oil are people running out there???
    i got a stock 454 bbc and i wanna know what a good oil and oil filter is for my motor.
    what weight, type (synthetic/ non synthetic), and brand of oil are people out there running.
    heard somewhere that synthetic wasnt good to run because it wasnt a good rust inhibitor...
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    Amsoil...........
    Massachusetts
    Mobil1 20/50 summer, 10/30 winter
    I put in a steel oil pump drive. Don't like the idea of warming up with 80+ psi and a plastic coller.
    Alamogordo NM
    Default No more zinc!
    I run mobil 1 with zddplus additive because almost all oils on the market now contain no or negligable amounts of zinc, which is what best protects solid lifters. Anything that is "emmesions compliant" has no zinc in it.
    I havent heard the "synthetic is not a good rust inhibitor" thing but I will look into it.
    Aug 2009
    Quote Originally Posted by bc18 View Post
    amsoil 10-30
    Senior Member GRoper's Avatar
    rotella 15-40
    volkswagen junkie eek-a-rat's Avatar
    Jul 2009
    Fremont,Ca. NOR*CAL
    Quote Originally Posted by 74glencoe View Post
    thats how i do it!
    chevron delo & zddplus.
    you cant polish a turd, but you can roll it in glitter!
    Senior Member Texgo's Avatar
    South east Texas
    I've heard that Rotella is a good oil. I have used it in my big trucks for years. I had an engine built for a pickup, and the builder recommended Rotella multi. I have Royal Purple in another pickup that we built, and I hate paying for it.
    The Right Coast/SE-PA
    Quote Originally Posted by Texgo View Post
    Rotella is a good oil...but I feel it belongs in a low spinning rpm Diesel >where it's designed to be >not a higher sustained RPM boat engine. Higher RPM's want to sheer a oil apart
    Just saying, I tried it and didn't care how water thin it became. Personally, I feel better with a 'race oil' in my engine.
    There are some GREAT race/performance oil's out there that have the zinc etc some are looking for > Brad Penn is just one of them. http://www.bradpennracing.com/
    Alamogordo NM
    Default Rotella and delo
    Both Rotella and Delo 15-40 are made for diesels in my opinion, the have alot more of the anti foaming agents in them than other oils.
    I run Rotella 15-40 in my powerstroke and will never trust it to anything else. If you want to start a fight with diesel guys just ask them which is better Delo or Rotella. Three days later you still wont have an answer but you will have enjoyed the fight.
    so rotella bad for jet boat? I was running castroll until one of my buddies/"motor guys" recomended it. he runs it in his boat and race car if im not mistaken. (10.78 e.t. n/a small block falcon) just lookin for some oppinions.
    Quote Originally Posted by Rivernut View Post
    Are you running a high volume oil pump?
    As for me...Valvoline VR1 20/50 at the moment. VR1 still has the ZDDP in it, which is only needed for flat tappet cams. Gonna do some experimeting with running thinner oils once I install an oil temp gauge.
    Senior Member W.O.T's Avatar
    Campo Ca
    i run valvoline racing 20w-50 and a k&n filter and change it often.
