Oil line sizing ?
Results 1 to 14 of 18
Oil line sizing ?
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Oil line sizing ?
    What is the recommended line size for a remote oil filter ?
    -10 AN is what I have
    The Right Coast/SE-PA
    Hey Sleek > question?
    Is the ID of a #10 line the same ID as a 1/2" NPT?
    Reason...(if) the #10 ID is bigger vs the remote filters 1/2" NPT (in/out) why not just go with the same 1/2" ID for the oil line? Gotta squeeeez it down past the 1/2" NPT anyhow.
    I have a remote filter set up...just not ready to install it yet.
    Hammer it's -10 AN fitting and hose 1/2 NPT adapter fitting. I bought a Canton remote filter kit, it included everything.
    Shell Knob, MO
    Be careful with those adapters. I've had several customers kill good engines because of them. If you take a good look inside of a lot of them, you can see how they can cut the oil flow almost in half. just my .02.
    I take that back... it's -12 AN fitting and hose. I bought a Canton remote filter kit, it included everything.
    Are the in/out at the adapters still 1/2" ?
    yes
    Looking at mine above that's what I thought too...so which ones are a good brand?
    My above remote is from TransDapt
    i'm back!! 1QuickCP's Avatar
    Montana
    always have machined my own adapters and run -12 line.....never a issue
    Silverdale, Washington
    Droppy, I've ran -12 before with no issues (though way smaller motor than yours) and have some -12 full flow 90s that you're welcome to iffn you need them.
    Colorado Springs
    Quote Originally Posted by DaytonaTunnel View Post
    Wh.at is the recommended line size for a remote oil filter ?
    I just finished a remote filter on my mark 4. Went with the Rex MAR billet stuff. 3/4 holes and 12an lines. 12an lines will take away all doubt. I also went with the hp6 filter because of the 1.5 inch filter mount.
    spokane, WA
    I am running -12 on my set up Chris
    Travis
    The Earth
    Blog Entries
    24
    Quote Originally Posted by jungledave View Post
    Good choice Dave (not just because I make em either). I prefer -12 because it insures good flow. Every hose of length increases wall tension which affects flow over it's length. Cost from -10 to -12 is minimal.
    The fittings I use I also make. They have a radius to insure max flow through the fitting, not just a standard old 815 AN male to mail union. Sharp edges and flat surfaces sticking out reduce flow. Perhaps it's overkill. Personally I like overkill.
    Here's a link to the billet stuff.
    Block bypass adapters both Mk4 and Gen 5-6.
    San Diego, CA
    x2
    -12 lines, rex billet adapter with 3/4" npt and a System 1 remote filter head with -12 fittings. Baldwin filter.
    Boat 405.
