Holley Electric Fuel Pump Question...
Results 1 to 7 of 7
    Member Jethro Jugbottom's Avatar
    Feb 2009
    Default Holley Electric Fuel Pump Question...
    Can anybody tell me were the over flow hose connects to the carburetor?
    Shell Knob, MO
    Or in to the special orfice on a covered engine flame arrestor where there is not vacuum pulling on it all of the time.
    Feb 2009
    Is it bad to connect it to the vacuum port?
    That would make sence, or at least more sense than uder the carb.
    S CP
    Quote Originally Posted by Jethro Jugbottom View Post
    I guess it is safe to assume you do not have a "marine" carburetor? If you did, you would see a connection for the necessary hose somewhere high on the main body. This connection would lead into the top of carburetor throat.
    Your best bet is to follow Duane's advice above if your carb is not equipped for the hose. Worst choice would be a vacuum source, as it may actually pull fuel past any internal seals in the pump. That's not the intended purpose of the vent system and could potentially create performance problems and/or early pump failure.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Saw it happen to someone's boat just a couple of years ago.
    Jet boat service
    Sebastopol Cal.
    Duane is exactly right. This hose goes to an air cleaner port or, as suggested, the port on the neck of a marine carb. Not a vac source. Jim
