Berkley (bowl)
Results 1 to 9 of 9
Berkley (bowl)
    Jul 2009
    Default Berkley (bowl)
    Ok guys, I need some opinions here... I think I know the answer (replace the bushings) but is there more damage that I dont see?
    Thanks in advance.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Replace the bushings and DuaneHTP at http://www.hi-techperformance.com/ has a shaft repair kit. To me, everything else seems ok.
    Wags
    The shaft looks to be well worn and liley out of tolerences in both the hard chrome and seal areas , you'll be ok with a new used or reconditioned one , the bushings are part of all base jet kits and easy to replace , repairing the shaft with a repair sleeve takes a lathe as you might imagine let me know if we can help Tom
    Sacramento, CA, USA
    How long to get one repaired? How much?
    Wags
    Greg please check PMs
    Jul 2009
    I just mic'd the shaft (not calipers) and the difference between the un-worn shaft and the worn parts is .002 in overall diameter (not as bad as it looks or feels) but none the less its worn. As far as a lathe, no problem there... my issue is time/deadline and I really dont have time to pull it out and chuck it up as I have yet to paint, re-carpet, rebuild the carb and put in all new gauges (which Ill be calling you about Tom). So long story short, I am hoping that the shaft will be ok for one more trip to Mead in Sept.
    Sacramento, CA, USA
    Ok, why did you pull it in the first place? Was it making noise?
    Wags
    Jul 2009
    I was pulling it because I am taking it to be powder coated again. Since this is my first experience pulling a Jet apart, I wasn't sure if this was damage or just normal wear and tear.
    Sacramento, CA, USA
    I would have waited until the last outting and then took it apart.
    Wags
