Let's See Your Nitrous Set Up
Results 1 to 14 of 41
    Cool Let's See Your Nitrous Set Up
    Hey guys. Just wanted to see what kind of nitrous set ups you were running. I want to put a little shot to my Chevy, but was probably just gonna run a plate "Cheater" set up. I heard some guys running low shots and getting double the horsepower from them
    So let's see whatcha got, What motor specs you have, what nitrous set up, how big a shot your running, how many RPM gains you're getting, etc
    Cricket....cricket....cricket
    Quote Originally Posted by Pw_Tony View Post
    And that is probably all you will hear! I have seen guys run nitrous that you could not find with both hands and a map Alot of times if they show they are not showing it all. Sometimes they show it all and it is what it is. I have seen some pretty nifty tricks to hiding a bottle and lines, especialy on boats. M
    I was thinking of that But my Victor Jr. intake prevents me from drilling into the bottom of the intakes ports and plumbing through the valley... and I don't want to drill into the heads
    Okay that is well understood, but have you ever heard of drilling into the bottom of the plenum and installing a spray bar? then comes the inlet lines, If you ever suspect a secret just count the water lines unless it is all internal. I have seen guys go with an oversize pan and put two 1# bottles in the wings of the pan. In case you can't tell I have done some street racing and boat racing for moneyM
    You can always have something like this done:
    S CP
    Senior Member n8dawg's Avatar
    Santa Paula
    One of thoughs guys huh? Id like to hear more stories about that, but not on a open forum.
    100-800hp adjustable 2 stage plate system i had on my gwing's 505
ID:	51211   Click image for larger version.
    S CP
    i really don't understand why you can't by a affordable kit to do a variety of intakes with . nx or nos need to make a kit!
    S CP
    Is there any advantage to a spray bar set up over a plate system??
    its basically the same thing as a plate, without the plate hella lot nicer imo, no extra gaskets and its hard to see, you can easily hide the plumbing and have a sleeper kinda like sleeper cp had in mind
    It solved 3 years of burned pistons because of a distribution problem with two different plate systems. Very clean shot to the ports and if you want you can run longer lines to the tubes and hide the solenoids.
    That's the old manifold the new one has the same type of set-up. As Tom stated " clean set-up" no plate or gaskets add the cost of shipping to the Nos shop the cost is not that much more than a plate system. You can't see it but it was set-up for 2- 300 hp systems. I could run 4 spray bars. Only did so 3 times, 200 hp and 250 hp systems.
    S CP
    Quote Originally Posted by n8dawg View Post
    hey dawg, I don't and never have used nos! But when you are out having fun and get 'called-out' you learn real fast how to find the juice! If you want to find out about hiding, shoot me a P.M.
    call him its so much fun to squeeze on someone when they never you had it to begin with start getting picked on by the fella with the 13 to 1 540 na motor, and put it on his ass with a nitrous 468
