help
Results 1 to 7 of 7
help
    BOOMER SOONER 426hallet's Avatar
    sacramento,ca
    Default help
    ive got a bbc with a tunnle ram and two sideways mounted holleys , now is there a bracket out there that i can buy to mount my throttle cable to the intake .. EVRYONE IS TELLING ME I HAVE TO MAKE ONE
    Bakersfield
    Quote Originally Posted by 426hallet View Post
    I don't see any reason you couldn't use a standard cable bracket, I could be wrong but check these out and see if you can make one work.
    http://www.rexmar.com/page198.html
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    what linkage are using?? I had to make my bracket for the cable, if you want you can stop by and look or I can post a pic, let me know, I have the metal if you want stop by and we can make one
    get blown or get blown away
    Member SCracer1's Avatar
    Try going to SummitRacing.com and doing a search on (tunnel ram linkage) should come up with a few choices.
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Summit has this one Weiand Hi-Ram Kit. Or if you do have to make one, here's an idea. http://www.weiand.com/data/Products/Technical/W543.pdf
    Wags
    sacramento,ca
    thanks corey ill have to do that. chris was saying that its easy to make i was just hoping that there was somthing out ther i could buy..
    hey greg i allready have the carb linkage i just need the bracket to hold the cable . my carbs are not inline they are mounted sideways so noone really make a throttle cable braket.
    Do the summit deal I did , nice and easy to install Tom
