Boat Flipping
Results 1 to 14 of 26
Boat Flipping
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Default Boat Flipping
    Does anyone remember or know who posted these photos?
ID:	51409   Click image for larger version.
    Wags
    bullhead city
    no but when we have done this we set tires on the ground to protect the side of the boat
    Sacramento, CA, USA
    I don't think the sides touch the ground as this is just a rotisserie set up. Here are a couple of more photos. Maybe someone knows the guys in the last photo.
ID:	51413   Click image for larger version.
ID:	51414   Click image for larger version.
    Wags
    Junior Member TNT CUSTOMS's Avatar
    Aug 2009
    Somebody went to a lot of work setting that up. Tires on the ground a couple buddies and an engine hoist on the bow hook worked pretty well for me. I've seen some other people do it inside the garage with a hoist hanging from the rafters and an engine hoist on the bow eye... Usually took a total of 30min - an hour if you include rounding up a couple helpers.
    Sacramento, CA, USA
    I guess all that work would be worth it if you were in the business. I think I'll go the "A" frame and cherry picker route like Hal did.
    Wags
    Colfax, Ca
    Member The Chaz's Avatar
    Susanville, CA
    I used 2 cherry pickers to do mine one strap around the bowl, one through the bow eye. I flipped it over without help and problems the second time. Just remember to to be SURE the strap cant come loose.
    "The Constitution only gives people the right to pursue happiness. You have to catch it yourself ."
    - BENJAMIN FRANKLIN.
    Sacramento, CA, USA
    My problem is the pump isn't installed.
    Wags
    Sacramento, CA, USA
    I have no bowl to strap to.
    Wags
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    i did mine with 6 or so tires and 5 buddies. when u go to flip it right side up i would suggest more people like 8 or more if possible
    Sacramento, CA, USA
    I need to be able to do this alone since I'll want to do things in my own time and not have to count on anyone else. I like the idea of the pump hole set up above.
    Wags
    Charlotte, NC.
    I have only been part of one boat flipping but with a half dozen or so dudes it seemed pretty simple. If i didnt have no freinds i would go find some vato's and get it done.... unless i did it alot i would not build something to do it.
    http://www.performanceboats.com//showthread.php?t=42724
    Sacramento, CA, USA
    I'll end up flipping 2 boats. One is a 19' Miller and the other is a 16' Tahiti. I guess I could visit the Home Depot lot and see if I can get a couple of cardless workers to help for a 12 pack.
    Wags
    Senior Member tahitijet's Avatar
    on mine i used the tires/grass and ton of people way of doing it. On the one i just did I sandwhiched the transom with 2 2x6 (1 inside and 1 outside) and bolted them together through every existing hole i could find on the transom. dead center i through bolted a eye hook with large washers on both sides and left it just slightly loose so it would spin. hooked a engine hoist on both ends and was able to flip it both directions by myself very easily without every pulling it out of the garage.
    pretty much similar to whats is showen just i used to hoist. advantage to the way i did was i could pull the trailer in all the way to one wall hook it up and pull both hoist towards the other side and pull the trailer out before flipping it.
