460 d9te-ab
Results 1 to 7 of 7
460 d9te-ab
    Member Targa88's Avatar
    Aug 2009
    riverside
    Default 460 d9te-ab
    D9TE-AB is this block good for 450-500hp is the block good or shtt
    Texas
    Any BBF block is good for 800+hp no problem and i've seen plenty with some upgraded parts with over 1000hp hold together just fine.
    Jul 2009
    I was told that any 385 series ford block can put out the ponies. Look at the thread about chevy's v's ford. Look at lakes only, something like that. He builds fords, has or can get what you want. he is the guy i am going to use for mine this winter.
    Aug 2009
    riverside
    so the late block is better then the early block I have not got it yet but I was looking at this one whats a good price for that
    thanks for your help
    Clovis, Cali
    Targa88, There are some differences, check out this link to High Flow Dynamics BBF block differences. And get a hold of LakesOnly !!
    http://www.highflowdynamics.net/?
    San Francisco Bay Area
    Cool
    Quote Originally Posted by Targa88 View Post
    D9TE-AB is this block good for 450-500hp is the block good...
    Generally speaking, all 429/460 blocks are good candidates for performance builds, and certianly 500 hp is a walk in the park and can be done with the factory iron. Late or early blocks, neither is necesssarily better than the other but sometimes one may consider using one block over the other, depending on the particulars of the build.
    How big is the engine you intend to build? A 0.030 over bored 460? Or a 500+ cubic inch stroker?
    Lastly, we have dozens and dozens of cylinder blocks for sale over here, and I can help you select a block that would be a good candidate for your engine build. Or I can answer questions that you have and help point you in the right direction for your build-up
    LO
    High Flow Dynamics
    Sep 2009
    Default Hey Paul...
    Instead of Sending me that Offy T-Ram you owe me...just send me out a D9 block that'll take a .080 over Bore .... So i can start my Stroker build...
    Good to see ya again !!
    ~Russ
