Pump expert in Bullhead/Havasu area
Results 1 to 13 of 13
    Member Leeminator's Avatar
    Fountain Valley, Bullhead City
    Thumbs up Pump expert in Bullhead/Havasu area
    I've got a 21' 1996 Eliminator, 207 Skier, with a Dominator jet. I have 60 hrs on the Dominator pump, 30 hrs on the rebuilt stock 454 motor, with a 4 bbl Edelbrock carb. My max RPM's are 4200, and top speed is 43 mph. I have a place diverter and I have played around with it and all I can sqeeze out is 43 mph. The boat is in Bullhead City and I want a shop with a good reputation to check the engine/pump to see how I can get a little more top end. If I have to take it down to Havasu, no problem. Any help is appreciated.
    Kingman/Golden Vly, Az
    u might want to check with Jim (Squirtin Thunder) on the boards here...he is located in BHC...he does good work & rebuilds alot of pumps
    FastRat
    Quote Originally Posted by Leeminator View Post
    With those numbers I would guess that you have about 330HP and an A impeller? Sounds like maybe a fuel problem, unless the pump was not setup right. With those numbers you should see about 50-55mph.
    What size is the Edelbrock?
    Maybe some else can give better advice?
    Always Have Hope
    Thanks FastRat, I will look for Squrtin Thunder....
    MAXXJETT, you are right, 330 HP, A impeller. I don't know the size of carb, only that it is a 4 bbl. I would be very happy with 50-55 mph.
    Thanks for your help
    Jet boats love fuel, I would say that you need about 750cfm carb. There is a good chance that the Edelbrock is only a 600cfm. You may want to run the numbers on the carb, to find out.
    Always Have Hope
    Is there a visual inspection of the carb that I can do that will tell me what size it is?
    There should be numbers stamped on one of the sides.
    Always Have Hope
    Cas
    Cas is offline
    Angry American Cas's Avatar
    here's the Edelbrock carb numbers along with what cfm they are-
    1403 - 500 cfm
    1404 - 500
    1405 - 600
    1406 - 600
    1407 - 750
    1409 - 600 Marine
    1410 - 750 Marine
    1411 - 750
    1412 - 800
    1413 - 800
    1403 - 500 cfm
    1404 - 500
    1405 - 600
    1406 - 600
    1407 - 750
    1409 - 600 Marine
    1410 - 750 Marine
    1411 - 750
    1412 - 800
    1413 - 800
    Thanks, this will help me!
    Razor Wire Militia 髯岙喢殮作's Avatar
    Lake Havasu, AZ
    here try this for Jim's number
    his website
    Cas
    Cas is offline
    you're welcome! Also, here's the link to Edelbrock's all you need to know about their carburetor pages-
    http://www.edelbrock.com/automotive_...ers_manual.pdf
    The number should be stamped on one of the front flanges were the bolt holes are.
    Bullhead City, AZ
    I take calls 24/7. I can work around your schedule so we can check out the boat/engine and see what is going on and how we can fix any problems. Give me a call anytime.
    BTW-Thank you everyone for the recommendation.
    Thank you
    Jim
    JR Performance Motorsports
    928-770-4394
    Jim & Amanda Rich
    CJ 72 & 53c
