My 1989 Tahiti 16ft!
Results 1 to 14 of 40
    Aug 2009
    Wisconsin
    Default My 1989 Tahiti 16ft!
    First off this is my first jet boat. Not really sure what I have here but for what I paid I figure I came out ok. It is a 1989 Tahiti that was manufactured by Hardin Marine. It does have full stringers in it. I'm told this is not the original engine. It now has a Chevy 350 full roller with a 500 lift cam. It does have a Berkeley 12JE pump on it with a place diverter, not sure if that is a plus or not. I'm told it has the stock impeller in it but with the deal I also got another stocker, a "B", and a "C" impeller. Few questions off the top of my head as for now,
    1. What impeller do you figure is in the pump now? He said it has the "stock impeller" in it. Chevy 350 Roller Rockers and 500 lift cam it will turn 5000 rpm.
    2. Pump maitenance? I see a grease zerk, I pumped quite a bit into it but didn't see anything ooze out anywhere. Keep pumping more in?
    3. Any words of caution with this manufacturer or with the set up? I know it doesn't have a rev limiter. Not too worried, I don't plan on jumping it or hauling the mail in rough water.
    Aug 2009
    Wisconsin
    Whoa sorry for the crazy post layout guys! I tried to fix it but no such luck!
    Senior Member 4trax's Avatar
    Shawano, Wi.
    Quote Originally Posted by Honda92 View Post
    Go back and hit edit, then place all pics that are in the [ ] below one another.
    I went in and got recircumsized again........I lost 10lbs. & was able to save the lives of 3 children in the burn center.........but it's not my fault they turned out to be dickheads.
    [email protected]
    Shawano, Wi.
    Like so.........
    [email protected]
    Shawano, Wi.
    Nice sled.
    [email protected]
    For some reason that's not what I imagined when I saw 16' tahiti? As far as the impeller cut goes, I bet if you post your top speed(mph) and rpm, we could come close.
    Colfax, Ca
    See if you can delete the first pics!!!!!
    Aug 2009
    Wisconsin
    Thanks 4trax for posting them the right way. I just deleted the screwed up ones and we will use yours! As far as top speed I'm not 100% sure. The guy I bought it from swore up and down it does 68mph as it sits on GPS. I have not checked it out for myself yet. I do know I can pull away from jet ski's with it. I think 68mph is kind of a far cry from what it actually does but we will see friday. He gave me a couple extra grates, he said if I ran the "C" cut impeller and this one grate it should be good for a extra 10mph. Again thats just his word, no proof to back that up. Is this boat even capable of hitting that kind of speed? I mean the thing scoots but I can't see it hitting near 80mph by just changing out a few things.
    Kingman/Golden Vly, Az
    Pump Maintainence...there should be 2 fittings on the bowl...1 on each side...(1 zerk & 1 plug)...undo the plug & pump grease into the zerk until it comes out of the other hole & ur good to go
    FastRat
    Aug 2009
    Wisconsin
    alright thats what those black plugs are for! How about that one closest to the engine kinda by the pump information tag? will i see any grease come out anywhere?
    FastRat
    From the factory, it would have two plugs and NO zerk fitting. It was designed to run gear oil not grease. Someone changed your setup.
    If you have two plugs, you remove them both and fill one side with 90wt until it starts coming out the other side. Reinstall plugs.
    Aug 2009
    Wisconsin
    Alright yeah i have the 2 plugs. Thanks for the info guys. keep it coming!
    What is the HIN (hull i.d. number)?
    Aug 2009
    Wisconsin
    I do not know off hand. where would I find it? on the tag with the capacities on it?
