people with 18' Caribbean or Tahiti
Results 1 to 7 of 7
    Bullhead city AZ
    Default people with 18' Caribbean or Tahiti
    What are you running, droop or snoot ?
    I am currently running this set up. And it seems to run well But .....
    http://www.danamarineproducts.com/Pr...7-9dc10f0a2800
    I want to try the straight snoot , yes i know i will lose my ride plate...
    i have talked to a few locals and they run a droop or stock set up's
    I know somebody here has tried a snoot
    Anybody..
    And before you say it..
    Yes my boat does get wet
    Bullhead City, AZ
    Steve I would recommend that you pull all the wedge out and just run the droop. The boat will be much quicker out of the hole and more of what you are looking for. I have set two of your style boat up. They seem to work real good with no wedge even with a heavy load. I would like to help you test and try some things out on your boat. Can you take a few pics of the bottom in front of the intake ?
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Bullhead city AZ
    I dont think i want to take out the wedge, i think it needs to stay if anything ?
    NorCal HotBoats Chili's Avatar
    Aug 2009
    Chico / Paradise
    Doesn't a wedge defeat the purpose of a droop snoot..?
    The droop sets the actual stream/flow lower in the water, & the wedge brings it back up.? (only at a different angle)
    Senior Member tahitijet's Avatar
    my 18' tahiti has always performed better with a good amount of wedge when using a droop. both on the bottom and top end. I'm going to go to a straight snoot for next season and see what happens.
    Glendale Arizona
    Quote Originally Posted by 2savage4you View Post
    I ran the straight snoot with 4.5 degrees up wedge. It was a hull deal and that boat required everything you could do to jack the nose up.
    When I first installed the snoot, I got no gains. Duane and I spent some time communicating back and forth and with his instruction and all that wedging, I picked up 2.5 mph on the big end.
    Worked great on my Kachina 18. I'm guessing similar hull.
    P.S. prior to putting the snoot on I was running the same Place Diverter droop you have there.
    Although to be fair, my pump was setback, I had a shoe and rideplate on it.
    After hours/days of tuning and messing around with different setups it was still a solid 2.5 mph gainer.
    thanks you answered my question in your edit.
