454 heads
Results 1 to 14 of 16
454 heads
    Member milpitasjet's Avatar
    Default 454 heads
    Im rebuilding my 454 this weekend and need my heads done. I got a quote for 265. Is that a fair price? They are 454 oval ports if it matters. thanks
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    got a set real cheap!
    Quote Originally Posted by milpitasjet View Post
    are they putting in valve guides in that 265? if so, that's not bad.
    how cheap? and imnot sure if they are putting valve guides in. He just said to redo heads and resurface.
    Jul 2009
    I would check. Does that also include the seats, vavle job? if so thats a good deal.
    i know for sure its a valve job ill check on the rest tomorrow thanks for the input
    That's not much money to "re-do" a set of heads. That can mean almost anything from grinding the 45 on the seats to a complete rebuild with new guides or liners sized correctly, a complete valve job, face the valves, etc. I charge $275 just to cut the seats. Noting more, but that's a 5 angle intake/rediused ex, valve job.
    You need to ask lots of questions for your $265.00, and find out exactly what you're getting and why (or why not). Have who ever is doing the work point out to you exactly where on the heads the work is being done...make him explain. If they refuse, take the heads somewhere else. Otherwise, you may just be throwing out 265.00, and if that's the case, throw it my way, would ya?
    Just tryin to help.
    Are they large oval or small oval? If they're small oval, those are truck heads and don't perform very well in a jet boat application compared to large oval ports. I'd check the casting number and find out before I went and spent any money on having them done.
    Thanks for the info ill look into that tomorrow for sure.
    Steelcomp, I appreciate the help. Too bad your not up here, but ill look into this more before i pay anything. Thanks again
    Get the casting number and post it up here, then I'll look 'em up for ya.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    here's the link to Mortec where you can look up the numbers to find out what you have.
    http://www.mortec.com/bbc.htm
    Senior Member bp298's Avatar
    LHC
    or this one
    http://www.chevcarclubvic.org.au/tec...ng_numbers.htm
    Senior Member GRoper's Avatar
    i had a friend open up a set of small oval ports for me. only flowed 285 cfm but the velocity was insane!
