CP 19' Gullwing
Results 1 to 9 of 9
CP 19' Gullwing
    You Cant See Me slough-cruiser's Avatar
    Kerman, Ca
    Default CP 19' Gullwing
    Just wondering if some of you guys that have the gullwings could give me a little help with deciding where I should place the motor. I got this boat as a bare hull with only the shoe installed. It has been set back and had alot of bottom work done to it I beleive it was done by Bennet down in southern cal. I plan on putting the motor all the way back and just using a standard pto (double u joint) is this going to be a good starting point or should I be starting with the engine forward with a short driveline and work my way back. I am using a a/b stainless impeller with a droop and diverter. The power is a 496 chevy with around 575 hp. Any ideas on mph or et with this info. Just wondering about the mph and et stuff I know its hard to say but im getting close to getting it done and am really excited. Hope to make an njba event by the end of the year. Any info will be much appreciated thanks.
    Junior Member 81sunkisst's Avatar
    Aug 2009
    Arkansas
    My motor is set all the way back with a double u joint. Runs good handles good. Also runnin a drop snoot and A impeller with a 396. Should do real good with a bigger motor
    whoever done the bottom work should tell you where to place the motor not internet guess'rs
    i'm back!! 1QuickCP's Avatar
    Montana
    575 hp....full back imho
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by 1QuickCP View Post
    X2
    oh and tom be quite today would ya
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    So, if you blueprint the bottom yourself, who do you go to to ask?
    Wags
    gullwings are actually pretty forgiven as far as where you place the motor. Just make the rail kit long enough so you can move it forward if you want to change it later. I've had everything from doulble joint to my boat now has a 12 1/4" driveshaft.
    Montana
    I ran full back until I was running over 1200 hp then started to inch her foward bit by bit...these boats will hold and run perfect to 105+ with correct hardware and motor full back. and u get more seating room.
    Kerman, Ca
    Thanks for the info guys I really appreciate it. Im I in the ball park thinking this thing is going to do 85-90 with my engine and pump combo? And I hope to have this thing in the water withen the next two weeks so I will post up the final results.
    Do it in the water
