Pump Problems
Results 1 to 12 of 12
Pump Problems
    6th Street Mafia PrecisionTile's Avatar
    Corona, CA
    Default Pump Problems
    I took these pictures earlier this year and I figured I would post them to see if my theory was correct on what might have happened. My theory is that I sucked something into the pump that dinged the impeller and caused it to be out of balance which in turn caused the end of the pump shaft to be worn heavily on the one side. I might be wrong but this is what I think happened. Any other input would be greatly appreciated. Since this was taken I have replaced the shaft, impeller, wear ring, bearing, and bushings. I had it all together but I learned the hard way that you can set a pump up too tight, I set it up a .005" and it ran perfect on the trailer but as soon as I put it in the water the impeller hit the wear ring and locked up.
    SOCIALISM: Tax Dollars At Work For People Who Don't
    The Right Coast/SE-PA
    Ha, been there done that...ONCE...12 years ago!
    I too set my pump up a .005 one time. Didn't realize how much the impeller (aluminum) moves/expands when loaded. Also, my new thrust ZKL bearing was bad. I tested it on a simple arm press with nothing but arm weight pulling down. Sucker had over .030 movement! .005 - .030 = lock-up real fast.
    At that time Tom Papp (great guy) had me send back my f'ed up Aggressor imp wear ring, and thrust bearing where he also tested and found to be bad. Sent me everything new and said .018 was a good number to use at the impeller, been there ever since, >sure miss chatting with Tom though.
    Note...when running a snug clearance check runout on the shaft and ALWAYS zero out the impeller on the shaft, on a lathe.
    Corona, CA
    X2 on missing Tom, he helped me set up my pump three years ago. At that time I think I set it up at .020" and it raun for three years until I sucked something into it. I have been told to set it up at around .030"
    B1 Racing cs19's Avatar
    That ding on the trailing edge did not cause the wear on the shaft.
    B1Racing.net
    Morgan Hill
    X2, that shaft is bent....or twisted...
    GT
    GT
    Corona, CA
    What would have bent the shaft? Could the impact of whatever hit the impeller have bent the shaft?
    Its not necassarily bent, my guess is its not bent and could be re hard chromed and used again. That area on the shaft could have worn like that for many reasons. Were the bushings in the bowl spun out or worn real bad?
    B1Racing.net
    DJD
    DJD is offline
    6TH STREET MAFIA PRES. DJD's Avatar
    Closer to the river than you!
    I had a shaft that was worn similar to that but not near as bad as that one. We checked the ballance on the assy and it was a mile off so when i freshened up the pump and installed all new parts i had Dugans spin ballance the assy. i saw an impeller that looked like that a while back but it was hooked up to decent hp and was being beat on loading and unloading under power. Probably not your problem just throwing that out there. Good luck.
    Morgan Hill
    Quote Originally Posted by PrecisionTile View Post
    I have a shaft in the drawer of shame that has a 15* twist with a slight corcscrew shape to it, not saying that is exactly what you heve there, but it does happen, I was referring to the heavy wear on the one side of the end....a bent shaft will cause ginourmous out of balance...
    I always etch the shaft on the ends and middle when using stockers to index it for straight, you will normally see a twist at the splines...
    GT
    GT
    Corona, CA
    The bowl bushings were in good shape. Thanks for the input guys, DJD are you going out for Labor Day.
    DJD
    DJD is offline
    Ya we are headin out thursday afternoon and staying till monday. What about you guys? I think we are staying at hidden beaches.
    Corona, CA
    I have to drop off my impeller at GS to be cut down one last time. I should be out there on Sat. Morning. I think we are going to stay back in town.
