need motor advice
Results 1 to 14 of 27
need motor advice
    Junior Member dboy1k's Avatar
    Jul 2009
    Default need motor advice
    well im new to the jet scene and im having some motor issues.
    i cant seem to get my bbc to stop popping through the carb at mid top to wide open. iv had it for about 3 months now and for the first 2 months it never did it.ive ask s few locals and they told me that the issue was to lean so i richened it up some, still no dice. had a guy check the valves,no dice.any help would be great
    thanks danny
    Morgan Hill
    Quote Originally Posted by dboy1k View Post
    thanks danny
    Start with fuel delivery, I believe you are experiencing a lean condition.
    I would start with a known good fuel pressure gauge and a vacuum guage on the manifold....This limited info will tell a long story....
    GT
    GT
    Charlotte, NC.
    Sorry to hear about your issue danny. Not sure i can give any meaningfull advice on the cause however i do have a word of warning...
    if you suspect a lean condition.... dont run your boat until you have it sorted out....I learned that the hard way... Pictures do all the talking.
    http://www.performanceboats.com//showthread.php?t=43887
    Co-Founder of SHB MarKist's Avatar
    timing maybe ???
    Markist
    "Life is SO much better now......
    blown mopar moparjet's Avatar
    manassas,va
    wiped cam lobe.. maybe
    throw it in reverse
    The Right Coast/SE-PA
    Quote Originally Posted by moparjet View Post
    Been there done that and yes the carb popped at mid rpm's.
    Could also be a vacuum leak thus causing the lean cough.
    Seriously, I would pull the valve covers, fire the engine and see (if) all the rockers are lifting the same amount. If you got one not moving much...wiped cam lobe and/or dead lifter, maybe bent pushrod.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Good ideas so far but I'd also check inside the distributor to make sure the springs on the centrifugal advance are attached properly. While you're in there, make sure the cap doesn't have a hairline crack in it somewhere.
    Actually, I'd start with the basics and the easy stuff, plugs first. then test each of the plug wires to make sure there isn't an issue with them, cap and rotor.
    Are you running a points distributor or an electronic?
    So Cal
    99% chance that you have a flattened lobe on your cam.
    Either flattened lobe or too much advance. A good safe starting point for a stock/mild compression naturally aspirated motor is to have about 34 degrees total all in by 3000 RPM.
    Jul 2009
    Quote Originally Posted by BUSBY View Post
    why would it do it at high rpms only? just asking because i dont know anything about this
    also if thats the issue how do i check it?and what would a cam cost?im not trying to get alot out of the motor i just want a good running boat.
    also thanks eveyone that has replide this site is awsome
    danny
    Yucaipa, California
    Timing?
    1992 Eliminator Daytona 21'
    Jul 2009
    well i dropped it off at the local speed center and they are going to check the cam deal so by this afternoon perhaps we will have an answer
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Good Luck. Post lots of pictures.
    Loose, the Dogs of War!
    thanks danny
    While you were in the carb, did you check and/or adjust the float level? If the float level is low, you can run the bowl out of fuel at higher speeds.
