Thread Seal
Results 1 to 12 of 12
Thread Seal
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Default Thread Seal
    I've got a remote oil filter set up and for some reason the lines are leaking at the oil filter firring. What's good for sealing the threads?
    Wags
    Rollin With Fink fasterthanu's Avatar
    Norcal
    I have the stuff for stainless fittings it's called PSP and it will not leak! if you come by with the boat you can use some. I am in CH.
    Sacramento, CA, USA
    Where can I pick some up? I'm not always a fan of teflon tape and you can't use it here any way.
    Wags
    Norcal
    No clue maybe napa or grainger i have had it forever. but it's the stuff.
    Sacramento, CA, USA
    And it's just called PSP? I'll have to go find some. I sure don't want oil leaking everywhere. Thanks - - Got the PM
    Wags
    Kingman/Golden Vly, Az
    I'm not a fan of teflon tape and you can't use it here any way.
    why cant u use teflon tape??...everybody uses that!
    FastRat
    Check that housing, if it's cast, it may have a crack!
    Sacramento, CA, USA
    FastRat
    It says not to for the remote filter housing is all I know. SO I found the thread seal at Auto Zone. Better safe than having something flushing through that wil plug up something.
    Wags
    Sacramento, CA, USA
    It's coming from around the threads. But thanks for the tip, I'll check it just to be sure.
    Wags
    El Cajon, CA.
    Speaking of threads, is this thread directly a jet boat technical question?
    Sacramento, CA, USA
    Nope, we'll let you slide on here too rod!!!
    Wags
    Las Vegas, NV
    check for cracks if its cast.
    been there, done that.
    i'm changing to billet
