remote oil filters
Results 1 to 6 of 6
remote oil filters
    Jul 2009
    Hesperia California
    Cool remote oil filters
    What is the purpose of having two remote oil filters instead of one on the engine block.
    cj812 ralph brunt's Avatar
    long beach
    more oil capasity (sp) more filtration and easier to change
    Spiral out MikeF's Avatar
    Better profits for the oil and oil filter manufacturers.
    More weight in the boat.
    Spending $ on setup.
    Potential for more oil leaks.
    Not being able to get all used oil out of the system.
    lol
    San Francisco Bay Area
    Cool
    Quote Originally Posted by jet pilot View Post
    • Engine oil capacity is increased
    • Engine oil filtration is "improved" (double the filter media)
    • Intervals between oil changes can be extended (more oil volume + double the filter media)
    • Engine oil flow restrictions (due to filtration) can be reduced (same volume of oil movement distributed through twice the filtration area)
    • Most dual filter setups have the oil filters plumbed in parallel. This way, if one filter fails/becomes clogged, the oil can still flow through the other filter
    LO
    High Flow Dynamics
    Exhibit #1........
    Quote Originally Posted by cj222 View Post
    I got to meet a few new people on Friday! I had an oil leak and on the way back from the sand bar i lost oil pressure and had to float back. It pumped all the oil out of the motor. So I just hung out with friends at Twin Palms the Sat and Sun.
    Pulled the motor today and found the remote oil filter adapter on the block was not making a good seal even though it was tight.
    with your ol lady
    Make sure you mount the remote at the same height as the old mount or just a tad lower. Lower (1/4"- 1/2") would be my pick. What your trying to do is lessen the amount of strain on the oil pump shaft pumping the oil UP HILL. And everytme you shut off the engine the oil wont drain back into the pan. The directions dont mention this.
    No more Mr. Nice Guy !
