Noise complains
Results 1 to 14 of 17
Noise complains
    Sep 2009
    Default Noise complains
    well the police came to the cabin this weekend in alberta telling me i had lots of noise complains about my boat so what are the laws i have water injected open basset headers
    1980 hondo pantera jet boat running a 468 big block chevy
    Wow they actually came to your Castle , Thats harsh !
    Sep 2009
    yup they came and gave me a stern warning well in one ear out the other and i carred on as normal wow much money is it to swith over to going thru the transom thanks colin its a 468 big block chevy on a hondo jet
    Spiral out MikeF's Avatar
    Where were you running your boat? On the water or in the driveway?
    Fab up a "cheap" modular muffler system that you can stab into the header pipes if you're running it in the driveway. Should keep the neighbors from complaining.......if that is the case.
    Sep 2009
    i was on the lake i have a bunch of aholes on the lake just jelous they dont have a boat like it has anone tried the super trap inserts
    I'd talk to Tom (jbp), those shot gun mufflers look like the ticket to me. Pull them shut when the db meter is out. Open them up when LEO goes away.
    Senior Member 4trax's Avatar
    Shawano, Wi.
    Get a set of these, you'll will be impressed. This setup here tested out at 83dB.
    More on it here.
    http://www.performanceboats.com//showthread.php?t=39665
    I went in and got recircumsized again........I lost 10lbs. & was able to save the lives of 3 children in the burn center.........but it's not my fault they turned out to be dickheads.
    [email protected]
    which lake you at??
    Senior Member Xerophobic's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by hondo man View Post
    Canadian law requires all boats to run either below the water exhaust or "muffled" exhaust. There is no DB reading but they do define that a "muffler" must be "an expansion chamber in the exhaust tract designed to adequatly reduce the exhaust noise". Thats paraphrasing but its worded very close to that. I do not believe one can do ANYthing to a set of OT's, dry or otherwise, in Canada to make them legal, except of course run them the required distance from shore when open exhaust is legal, which is like 5 miles or something and thats obviously catered to the offshore crowd.
    My old tunnel had thru transom Bassetts water injected which dumped below the waterline at idle and I still got a ticket once. I suppose if I was on a large body of water I could try to claim I'd idle out to the 5 mile limit but the min I am on plane within I "could" get a ticket. Putting a legal expansion chamber in a set of OT's is probably not very feasable so for all intents and purposes I consider OT's "illegal" in Canada.
    If you ain't hittin bottom...you ain't jetboatin!
    Feb 2009
    MANTECA
    Default super traps
    I ran some supertraps for a while, they seemed to quiet down my 396ci pretty good. I finally took them off because they would make the dirty water fall on the transome of the boat. They made no noticeable decrease in power.
    " Live Laterally " Dominator's Avatar
    Phoenix
    All I can say is Just a bunch of charlie rent a dick's being aholes! Fock em. If you have water going through them there should be no problemo amigo. They probably have nothing better to do. I dont know but sounds bogus to me. Keep making noise.
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Senior Member superdave013's Avatar
    get some Basset mufflers. 2 bolts and your done.
    Passin Glass HOOLI's Avatar
    In a state of confusion
    Thumbs up
    Quote Originally Posted by Xerophobic View Post
    SHOTGUNS !!!!
    Lightbulb
    Sylvan Lake??
