A bad weekend..not mine thank goodness
Results 1 to 14 of 38
    The Man cordog009's Avatar
    East Texas
    Default A bad weekend..not mine thank goodness
    Had 2 boats sink this past weekend at Broken Bow..one had foam in the bow and didn't go all the way under..this one went down in about 80' of water and stayed for 2 days. They finally got some tubes and stuff down and got it to float back up.
    1984 Youngblood TX-19 SOLD
    Member MRUSER's Avatar
    wow thats crazy...... kind of makes me worry a little about sinking.
    Spiral out MikeF's Avatar
    Where can I get one of those welded aluminum driveshaft lengtheners.......those are bitchen!
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    not good.did it sink because of the houseing broke.or did that happen while it was down?
    Quote Originally Posted by MikeF View Post
    Differently want to hear what happened on that deal
    S CP
    Anaheim/BHC- the Shack
    My guess is the "driveshaft" came apart (though the u-joints survived) and what remained flailing about on the pump end at 5k rpm took out the housing.
    Quote Originally Posted by fast76rogers View Post
    Good question.....no flotation....boat hits bottom at a good clip.
    BNAG!
    clearlake ca
    BNAG!
    i think something broke under power.look at the transom plates.exploded to the out side.ill but it was that shitty spacer.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    damn! I think you can ask fleetimus about that. Those broken parts damn near look like his did when it came back up from the depths.
    I think that is actually the cleanout cover that was pushed into the transom cover upon impact on the bottom.
    Charlotte, NC.
    I disagree.. It looks like that transom plate was covering half of the hand hole cover. Then when it went Kaboom the pump went backwards and ripped out.you can see where part of the hand hole cover had been painted and the damage to the plate definately goes outward.
    that sucks.. Glad im insured for loss.
    i'm back!! 1QuickCP's Avatar
    Montana
    I puttin money on the aluminum spacer...look at that thing,maybe .125 thick at the weld maybe less, plus they probably pressed it togeather and then welded it so goodby aluminum heat treat. I have made many pump spacers and there is nfw id EVER do one unless it is solid billet ...thats just nuts
    my uncle saw it happen, said the boat danced the transom some, so i'm thinking the suction housing prob had a prior crack and he finally opened it up. another boat there had a leaking nos solenoid, and when he went to crank it, kabooooooooooooommmmmm my uncle said he thought someone was shooting at him from behind it was soo loud and he could feel it.
    yall don't forget that when a boat goes down, it goes pump 1st, which is prob some of that ta plate damage
    The dude in the pic is standing on the bow of a Jet that sunk a few years ago at the narrows on a big weekend. I remember seeing the boat and 4-5 peeps on the transom, I looked away and next thing I saw was a shit load of cigarette butts a couple seats, beer cans, 20 gallons of fuel, and 6 people swimin' around wondering what the fu-k happened.
