cracked bottom again # 4
Results 1 to 14 of 28
    sacramento
    Default cracked bottom again # 4
    did my regular inspection & this is what i found..........Click image for larger version.
ID:	53686 guess i'm down for the count again
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Well that just sucks. What part of town are you in and maybe we can get a few hands over to help you get it back together. DOes it go clear through?
    Wags
    Vacaville,Ca.
    That's an off the trailer, flip it over job...
    Sacramento, CA, USA
    That it is, so start by pulling the motor. Line up a couple of cherry pickers and something to sit it down on. Pick up some resin and glass can some yellow pigment. If you only fix this you should be back right side up in a few days.
    Wags
    Parker Az. / Burley Id.
    Been through this on many boat repairs. That is caused by the lifting strakes not being filled and glassed over on the inside of the hull. Repairing from the outside is just a temporary bandaid. You will need to get the sub floor out and repair it on the inside. Most newer quality boats have the strakes filled with cabisil and then glassed over to eliminate the hard edge for the bottom to break at.
    Clovis, Cali
    Just an observation. Looks like you might have broken bunk on the trailer too (the inside one). Looks like there's quite a bit of room between it and the hull, and looks like the bunk has been hitting the frame. Might be part of the problem.
    Apache Lake Monger AZKC's Avatar
    Tucson
    I have the exact same crack have been fighting it for awhile, the outside patch is just as said temporary I cut out a piece of the floor last time and it lasted a little longer but I like the idea of filling in the strakes cause they aree just a layer of glass right now.
    sacramento
    no, it has like two layers there. i'm in south sac @ florin
    sacramento
    Quote Originally Posted by Riverbottom View Post
    that is what i thought. we just repaired it & had it going for spring of '08'
    sacramento
    Quote Originally Posted by propless View Post
    the bunk sags, i guess i could put another brace in there. i did hit a pretty big wake this last week-end
    sacramento
    Quote Originally Posted by AZKC View Post
    i have been looking for hours to find the pics of the repair in spring of "08' to see if i repaired this ares or it was more on the other side. can't find them yet
    Sacramento, CA, USA
    Can you see that strake from the inside or is it covered up?
    Wags
    sacramento
    hidden under the stringer.
    Same thing our "glass guy" just said re this boat , this was a small crack but a huge job inside and out!
    before
    after
