Just a Bit worried
Results 1 to 14 of 41
Just a Bit worried
    Senior Member OverKill's Avatar
    Default Just a Bit worried
    Guys can you give me some info on this. I just added Nitrous to the boat and my boat guru mounted the Nitrous bottle very back left about 1 foot away from the headers. My question is should I be worried about anything blowing up on me?? SCOM was over here the other day and we had this discussion. I'll put up some pics later today. Any info would be great.
    OK
    Banne'd Cobra1's Avatar
    Did you ask you "boat guru" why he put it so close? This way you won't have to wrap it with a heater.
    Senior Member cave's Avatar
    Mesa, AZ
    It gets hot out here in AZ. May not need the heater in Summer.
    Takin it home
    I wouldnt never run a pressurized canister new headers. Thats a problem waiting to happen. Why didnt you put it under the bow
    Quote Originally Posted by OverKill View Post
    OK
    Did you "Ask Phil Bergeron" yet
    East Side
    That was my opinion. I think as long as he runs water through the headers he should be ok, but I still don't think it's such a bright idea. If it was under the bow it would be too difficult for him to remove to refill.
    Senior Member ULTRA 23's Avatar
    Corona, CA
    If the pressure get to high it should just blow the safety relief.
    John D
    INLAND ULTRA CUSTOM BOATS
    Corona, CA
    951-734-6000
    Ultraboats.com
    Quote Originally Posted by ULTRA 23 View Post
    Ultra is correct, it will blow the safety relief and vent all your NOS into the atmosphere. One foot from the header is to close IMO it well add excessive heat to the bottle and raise the pressure. Sometimes before the pressure blows the relief it will stick the solenoid.
    If you are going to keep it that close build a heat shield for it.(IMO)
    Sleeper CP
    Senior Member jet454boat's Avatar
    mesa az
    i would run it under the bow for three reasons one its away from the hot headers, two its out of the sun the first two would cause a increase in pressure from being in the heat and cause it to blow the safety release and then you lose $50 on a bottle fill up, and the third when you want it on you dont have to climb all the way to the back of the boat
    not ****** little squirt's Avatar
    Waikiki, HI
    this is where mine is, although i have no back seat, probably put a towel over it if im going to be in the sun all day. can you get a pic of yours up here? hard to tell if its too close to the headers depending on the space you have in the gunel wells.
    not banned
    Mike I have some news for ya. Phil/Craig are the ones that put it there.
    Here is a pic of the set up
    man, you might wanna get a fuel pressure safety switch and put it up there by the fuel solenoid if that thing gets low pressure on the juice, its not gonna be pretty, especially with a single carb tram.
    Senior Member TrollerDave's Avatar
    Chino,CA
    This happened to us when we were going thru the channel at Havasu. The bottle was back by the headers, relief blew and it was loud and scary. My dad tells my mom to take me and my sister(9 and 6 years old) out on the bow (the deck was HOT).We're freakin out. He figures out what it is, "Ah it's just the nitrous". The bottle was eventually moved under the bow.
