Beede Tach
Results 1 to 10 of 10
Beede Tach
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Default Beede Tach
    I've got a Beede Tachometer and it has 4 setting positions, does anyone have the setting meanings? For some reason I'm not showing over 2500 rpm. Thanks.
    Wags
    Sacramento, CA, USA
    Must have stumped the pros on this one!
    Wags
    Have you switched the positions ?
    4-6-8 cylinders maybe ?
    See if you can find installation instructions on the net.
    S CP
    Sacramento, CA, USA
    The markings are 1 2 3 4 and the instructions just say to look at another discription. I guess I'll have to play with the setting and see what's what.
    Wags
    Dallas, TX
    I searched the Beede site and came up with nothing. I figured you would have an answer by now. They do have a support forum over there.
    http://www.beede.com/xSupport.php
    Southwest corner AR
    You need to check the guage part no. too! When my boat was sold it arrived with an O/B tach in it! Worked but was reading incorrect! FWIW! WT
    I do think 1=4cyl. 2=6cyl. 3=8cyl. 4=10cyl.
    WT
    WFL Crew!!!
    Sacramento, CA, USA
    Thanks for the link, I'll check it out.
    Wags
    Sacramento, CA, USA
    I'll check to see where the switch is setting. I'm getting only a 2500 rpm reading on my BBF and I know it's doing better than that. Thanks
    Just checked the switch settings and it was set at #4. If your numbers are right, it was wrong and now I set it to #3 to see what that does.
    Wags
    Do you have MSD? If you do you may need a MSD tach adapter, as a MSD 6AL may not match up with your tach. Just a thought.
    Always Have Hope
    Sacramento, CA, USA
    Nope. No MSD. I've heard too many bad things about them lately,
    Wags
