muffler tips in open header
Results 1 to 14 of 18
    Sep 2009
    Talking muffler tips in open header
    wondering if anyone is running muffler inserts in over transom exhaust i have bassett open headers just wondering what would fit thanks colin
    1980 hondo pantera jet boat running a 468 big block chevy
    Charlotte, NC.
    i got a set of these.
    Top right hand side
    http://www.rexmar.com/page237.html
    They work ok. i dont see any performance loss with them in and makes the law happy.
    Sep 2009
    u have to drill hole in end of the header then they bolt on am i correct thanks
    Alamogordo NM
    Quote Originally Posted by hondo man View Post
    Thats how mine work, 1/8" hole drilled in the header.
    Sep 2009
    Talking
    right on i will get a set might calm the people down on my lake haaaaaaa
    Senior Member CK7684's Avatar
    Minnesota
    I got my Bassetts with the baffles in them already. They arent all that much louder than my TT logs...mine had a bolt in the end, but these baffles arent coming out without destroying the headers, lol, so now I just have a small hole
    plano texas
    got a pair last year. ran them with a small amount of water.they discolored the ceramic caoting with in a couple minutes were the collector meets the header tubes.even drilled about 6 to1/2" holes in he middle.no water, ran it only a couple minutes, the discolor got worse.to me there a pile of dog dodo!
    The shot gun mufflers, have been working well for the guys in Wisconsin, they have to pass, to be let on Shawano lake I'm told each and every one has passed.
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    These are good up to 425HP
    http://www.cpperformance.com/detail.aspx?ID=354
    Best suited for higher HP applications
    http://www.cpperformance.com/detail.aspx?ID=352
    Depending on the application an average of 8-10 db reduction is common.
    Good luck!
    CP Performance
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    Senior Member Camoman's Avatar
    AREA 51
    Top right hand side
    Those are the biggest power robbers ever I think i got at least one set around someone can have
    There's doing it easy,or there's doing it better
    AREA 51
    Quote Originally Posted by CP Performance View Post
    Good luck!
    These are the ones to use for sure
    Charlotte, NC.
    Quote Originally Posted by Camoman View Post
    maybe but going as slow as i go you dont see a difference
    AREA 51
    Yes i seen a 350rpm drop from 5850 to 5500 on the water. Got the other and back th 5850
    Charlotte, NC.
    I was just kiddin.. i would kill for 5800.. im cruisin at 5K.
