Donzi Gt21 Jetdrive
Results 1 to 10 of 10
Donzi Gt21 Jetdrive
    Junior Member axelkloehn's Avatar
    Sep 2009
    Hamburg
    Default Donzi Gt21 Jetdrive
    Hi folks, I am new to this board. A big hello to you guys from good ol' germany.
    I bought a Donzi GT21 which was originally equipped with a Jet-drive as you can see from the cutouts. I suspect it was a olds/berkeley package, maybe 350 or 455 Olds.
    There is no hull # anymore because the cockpit area was cut away (someone wanted to make it a family boat ).
    I reglassed the transom and other things, put the cockpit area together again and now it is ready for a new engine and drive.
    I bought a 455 Hardin/Olds with mondello heads and a Jacuzzi WJ from a jetboat for a good price and want to put it in.
    Will that be a good package for the boat? The Donzi is quiet heavy!? I am not sure whether I stay with the original jet-package or line it up a Bravo 1 Sterndrive, which is lying around with all rigging in my garage.... It is than a bit tricky with coupler/waterpump etc. but not impossible.
    What performance will it have with the jet compared to sterndrive? You guys have definately more experience than I have...does anyone know??
    Thank you for your advice, Axel
ID:	54681   Click image for larger version.
ID:	54682   Click image for larger version.
ID:	54683   Click image for larger version.
    Sep 2009
    Hamburg
    Here is the Olds and the Jacuzzi:
ID:	54686   Click image for larger version.
ID:	54687   Click image for larger version.
ID:	54688   Click image for larger version.
    Norco
    Guten Tag!!
    Where in Germany? My folks are from Munich.
    The Olds and Jacuzzi is gonna be a fairly easy install. I would not expect much performance out of them. They will get you around and you will have a great time. If that is all you want, I would say go for it. If your looking for performance, then you might want to rethink power and drive.
    Prost!!
    Sep 2009
    Hamburg
    Quote Originally Posted by danhercules View Post
    Guten Tag!!
    Prost!!
    Well, I want to go around 65-70 mph, a bit more than the rest of the pack .
    Is that realistic with that package?
    I live in Hamburg/north of germany which is about 550mls from Munich.
    Cheers, Axel
    Shell Knob, MO
    Possible, but not probable. That particular Donzie hull was built for a stern drive installation and will perform better that way. It's really tool heavy for the Olds/Berk package. Demamding that much form the Olds will make it a short lived engine. I'd go with the stern drive in that one, (and I'm a jet nut).
    Duane HTP
    Axle Good Morning and welcome , I'd Agree with Duane here , not going to tell you it can't be done but 65-70 is a lofty goal with the Olds package in a boat that large we've done just about every "swap" you can Imagine and That boat unfortunaley would take some serious HP with a jet to make 65 IMO Tom
    High Rock Lake, N.C.
    I would take Duanes and Toms advice. Go with the stern drive and save the jet for something smaller and lighter down the road.
    Sep 2009
    Hamburg
    Hmmmh, I expected something like this.
    It looks like the Jacuzzi in line with the 455 Olds is too long anyway. My engine room is something like 50" long, the Jacuzzi has more than 20" from the transom and the engine 32". That tells me it does not fit!!
    Did somebody ever hooked up the 455 Olds engine with a Bravo One sterndrive?? What's with bellhousing and coupler? Power and torque should be ok from the 455 Olds for the Bravo, shouldn't it? I have been told it is 450hp...
    Shell Knob, MO
    You are on a jet forum here. To find the answers on the interchangeability of motors on that out/drive, I'd suggest you go to an I/O forum. I don't think it can be made to fit without a lot of engineering and trouble though.
    Charlotte, NC.
    ever thought of ditching that hull and finding a smaller lighter one for the power plant you already have? May be cheaper than trying to retrofit that power plant to a out drive. Not sure how many hulls like that in Europe though so that may not be possible.
