Jet Pump Question
Results 1 to 14 of 14
Jet Pump Question
    Senior Member Cobra 02's Avatar
    Montclair
    Default Jet Pump Question
    Just removed impeller from legand pump and this is what i found.
    Is this normal wear and tear.
    And how do I get the old wear ring out.
ID:	54953   Click image for larger version.
ID:	54954   Click image for larger version.
    Young Junior Member
    Sep 2009
    BBL
    Quote Originally Posted by Cobra 02 View Post
    i had replaced the impeller on my berkley if its the same we had to take it to a shop to get it pressed out...but depending on how big...mybe use some snap ring plyers...
    Bullhead City, AZ
    It looks like a few too many dry starts. On long road trips it is good to cover the intake to prevent road debris from collecting in the pump.
    It is real easy, just take a butane/propane torch and heat the wear-ring up and the insolator will melt so you can pry it out easily with a screw driver or two.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Quote Originally Posted by Squirtin Thunder View Post
    I've got a question, how do you do this?
    Wags
    B1 Racing cs19's Avatar
    That impeller is destroyed unfortunatly.
    B1Racing.net
    East Side
    As said, heat the wear ring up with a torch and it will come out easy. Definitely time for a new impeller too.
    HOLY surface galling Dale ! Imagine how that bad boy's gonna work with fresh horses and a functioning Impeller
    Oddly enough, I had the wear surface on mine galled up like that from too many skinny river and dry runs. I just filled the grooves in with Permatex "The right Stuff" silicone. Smoothed it into the grooves and ran the boat for another 2 months. Just pulled the impeller today. No more grooves and the silicone never budged. Gained the power back and never noticed any difference. Makes me wonder why Berk doesn't make something simular.
    Chantilly Va.
    I crawled under my trailer with a nice towel and a staplegun.Fold the towel in half,staple it to the bunks real snug to the intake. After two or three outings, you will undo one side and snug it up. Worked for two years so far.
    check with dewaye at hi-tech , i remember that at one time he marketed a guard or plate that went on the trailer bunks to protect the pump.
    Quote Originally Posted by ventureline View Post
    Wow thats amazing it held up in there.
    B1Racing.net
    WOW If only Billy Maze were still around (RIP) I could just see his ad for "Mighty mendit" , fixing a towel rack , a coffee mug and then an Impeller
    https://www.mightymendit.com/flare/next?tag=os|sm|go
    Newton Ks.
    Quote Originally Posted by johnray069 View Post
    It sux that his cover wouldn't fit my trailer (bunks too far apart).
    I put enough eye-screws in each bunk to pick up every hook from a ATV cargo net, stretched it accross the intake, and slipped a 2" thick square piece of packing/shipping foam under it. Held great, just yank the foam out before launching, left the net there.
    H.L. Mencken
    Senior Member GRoper's Avatar
    Make sure you far enough off the trailer before fireing her up!!!
