Bowl lube....grease or oil??
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 44
    Default Bowl lube....grease or oil??
    I'm sure this has been hashed out, but now that I have my pump apart and can see what's going on ...it makes me want to go back to gear lube instead of grease. What's your preference??? I just broke off the brass plug opposite the zerk, so a drill and a tap later there are shavings in all my old water soaked grease......It's not pretty.lol Any suggestions on that mess would be appreciated also. Oh fwiw it's a split bowl berk I working on.
    oldsmopile equipped
    Lake Lansing MI.
    about a month or so ago there was a thread about this, If I remember ...they were saying don't greese um, it will wear the shaft. but that's what A.T. tells you to do. A few friends of mine just pull the plug and run water with no problems.
    Quote Originally Posted by Adam View Post
    I haven't pressed the bushing out of my bowl yet ....but isn't the lube for where the end of the dl rides in that bushing? Water???
    oldsmopile equipped
    Lake Lansing MI.
    I mean the plug in the nozzle... the (at least mine) plastic one that you can see if you look into your diverter. but that's just what I have heard, I dont go that route. as of now I'm running a mix of 80-90 with a bit of Lucas to thicken it up a little.
    oldsmopile equipped
    Lake Lansing MI.
    I may be reading your response wrong, I'm just a lurker. but if you have your bowl off you can see that there is a crevice between the 2 bowl bushings, and on the outside of them is a bowl seal and a plug ( on the nozzle side). when you put grease, or oil, in your bowl that's where it goes. I dont know if guys running water pull the seal out or not. I'm sure some will tell me I'm wrong tho. Ill go back to drinking and lurking now.
    Charlotte, NC.
    i ran grease when my seal went to crap. But now that i replaced those bushing and seal i went back to grease. Which is better? I have no idea.. ;-)
    Spiral out MikeF's Avatar
    Berk = Heavy gear oil. 90w
    After every trip I force the oil/water mix out and put fresh in just to be on top of it.
    If you put grease in you'll end up forcing the seal out before the grease comes out the opposite fill/drain hole. Don't use grease on a Berk bowl.
    We initially designed our Bowl to be a Oil Lube Like Berk... After look at the run of Average We decided to change to a Lube system.... Dominator Runs a Dry Lube system which has major short falls in brackish water. So Roll The Dice on which system to follow...
    Senior Member Chris The Plumber's Avatar
    Sep 2008
    Chandler
    Default pump
    You can eliminate running oil completely, remove the seal & throw it away, you also have to remove the large cone shaped plug & throw it away as well, the plug I am talking about is on the opposite side of the bowl where the very end of the shaft is, You use a massive screw driver to remove this plug. With this done the water will lube & keep your shaft cool at the same time, you don't worry about sand or debris getting logged between the bushing & the shaft. Many peeps do this modification.
    Kachina Condor Tunnel hull
    Hondo Hydro pickle fork, dominator pump.
    Quote Originally Posted by Chris The Plumber View Post
    Funny Shit!!!
    Is it Summer Yet?! SoCalKev's Avatar
    Santa Rosa
    So what about when youre running it on the trailer???
    Run 90w in there.
    Sanger Super jet in Progress
    Sep 2008
    Chandler
    Default pump
    Funny shit!!!!!! well POP's its been working for me & many others as well, I learned this from a very well known Boat repair facility, Not going to throw names around, so WTF POPS????
    LF2
    LF2 is offline
    OC
    My boat was setup this way when I bought it, I havent had any problems with it so I plan on leaving it that way.
    Iuka, Mississippi 38852
    have been running without a seal or a plug since 1983. TX-19 lake boat. shaft looked good about 7-8 years ago. going to change impeller next spring. we`ll see.
