Diverter nozzle old style Berkeley
Results 1 to 14 of 19
    Senior Member Amango's Avatar
    Sep 2009
    Default Diverter nozzle old style Berkeley
    Hello, I'm new here but i had a ? On the old Berkeley diverter nozzle the one that looks like it would case drag do to the way it hanges down. Has enyone ever cut off that portion to ruduce drag or does it not make that big of deal. Thanks
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    It is very common to cut them flat.
    I have a new style, but I'm sure someone has a photo of the old style cut down... stay tuned...
    early and even later berk nozzles get cut down and modified in this area regularly , this will likely decrease the "efficiancy" of an already marginal reverse however Tom
    Sep 2009
    I was thinking it would help and be a little cheaper then buying a new one. On another note,"Impeller" I'm running a B-cut aggressor and turning 5600 RPM just advanced my cam to 6 degrees adv. on the crank trying to bring the curve down to the rpm range. 11.92 comp ratio 466 ford tunnel and 1050cfm carb. EST hp 600 the cam is a Schneider 306-14 R soiled roller. I built the engine to turn 7000 RPM but i think i have the wrong impeller and might be overloading the pump with the shoe and loader I'm running. The boat is a 77 Eliminator bubble deck with a delta bottom. Trying to brake the 80 mph mark. I was thinking of removing the loader to see what that would do. Thanks for the reply. I will try to post some pics of my set up.
    Are you refering to the prehistoric Berkeley steering nozzle like this? If so time to update, to a Place Diverer.
    Kingman/Golden Vly, Az
    Hey Tom...
    do u have a pic of a nozzle that has been cut down?
    FastRat
    oldsmopile equipped
    Lake Lansing MI.
    if ya want to run a stock nozzle, IMO... cut it off flush just like a diverter.. or better yet order a diverter from jbp, they have a very fair price and you should pick up speed. and you can show off with your roost
    Hey Tom...
    FastRat
    F/R I probably do I litterally have hundreds of these in tubs I'll look tommorow , funny thing , were actually "lengthening" this one
    Senior Member G-Body's Avatar
    Downers Grove
    On that prehistoric nozzle, what is the indentation in the back for? The part below the outlet on the back of the reverse hook. Was this a spot to clip in a ski tow? or so you could attach a hose to use as a firehose? or what?
    10' Custom with 25 Merc_____17' Sleekcraft jet____85 El Camino SS 5.3L/4l60E 3.73 posi____1980 Chevette 4.3L v6/4l60e____www.fquick.com/G-Body
    Sep 2009
    I modified mine yesterday its not that old. I will take a picture and post it after work. I cut it flush. Just trying to reduce drag where ever possible. Thanks for the help
    Quote Originally Posted by G-Body View Post
    The "V" shaped slot was actually for a drop in "break away" rudder The nozzle Chuck posted has been "modified" (for a later style Berk rudder)
    and yes Berkeley did have a fire hose attachment of some sort for the pumps (i'll dig for the pics) Tom
    Sep 2009
    Here are some pic's of the modified diverter cut flush. I was thinking of welding a plate on the bottom to make it like a newer diverter nozzle, But i don't think at WOT it drags in the water. I hope i have a little reverser left not much in the first place.
ID:	55621   Click image for larger version.
ID:	55622   Click image for larger version.
ID:	55623   Click image for larger version.
    Young Junior Member
    Sep 2009
    BBL
    Lightbulb
    Quote Originally Posted by Amango View Post
    if you drop it down you get more reverse power.
    Young Junior Member
    Sep 2009
    BBL
    WTF are you talking about?
