Running out of water
Results 1 to 14 of 17
    Sep 2009
    Default Running out of water
    Im not new to boating, but new to jet boating, can someone tell me if there is a good way to run my boat (at my house) and wet the jet pump. I can set up the engine no problem, but was wondering what an effective way would be to introduce water to the pump. Some mentioned to me I can stuff a hose into the outlet of the pump while running, but that didnt seem do right to me,
    thanks
    Senior Member T-Train's Avatar
    Jul 2009
    Lebanon,Or
    Quote Originally Posted by Sunkisst6160 View Post
    thanks
    The best way is to disconnect the drive shaft. Then you just have to hookup the water to the engine.
    DON'T RUN THE PUMP OUTTA THE WATER!!! disconnect the pump if you have to , but don't run the pump outta the water!
    Sep 2009
    I thought of disconnecting the drive unit, but there are two universals, one at the engine and one at the pump,
    If I disconnect, which is not difficult, the universal at the engine will flop around and cause serious damage, and it cannot be removed without major dissassembly, so thats not practical. So there is no way to run this engine unless Im in the water??
    take the driveline loose from the power take off (back of crankshaft)
    Charlotte, NC.
    New Jersey
    ....... So there is no way to run this engine unless Im in the water??
    The general concensus of the experts is that running the jet on the trailer will cause accelerated wear on the impeller and wear ring. This is made worse if there happens to be grit and debris that has been kicked up from the road while trailering.
    The best way is to disconnect and remove the universal joints.
    That said, some people will run thier jets on the trailer by squirting water in the jet intake or bowl or back through the enging cooling water port. If you make sure the jet is clean, flood with water and limit the run time to the minimum you can do this with little to no damage/risk.
    If the jet is old and near needing a rebuild then it is less of an issue, but a new, tight pump you risk loosing efficiency and hurting performance by increasing the impellor/wear ring clearance.
    Doug
    Chantilly Va.
    If you disconnect at the back of the crank,You may have enough room to slide the shaft,and/or the u-joint assy back into the pump far to gain clearance to have enough air-gap to run your engine without damage to parts. This works for me in my application. Doesnt neccesarilly mean it will work in your application.Be careful and good luck!!! Where you get headers like DAT ?
    Quote Originally Posted by sunkisst View Post
    good advise, i've had a couple boats i could do that way, i just used zipties to hold the shaft away from the pto, let r rip tator chip
    thanks
    That will work if you got the motor cover for water... All you need is water around the Wear Ring as a Lube, thats what it uses in the water.
    Just keep some water going on it..
    Newton Ks.
    Sure there is.
    Run a 4" hose from the nearby fire hydrant to your intake, open the hydrant wide up, and fire it up. That should keep things wet enough, as long as you don't zing the throttle too much.
    I always fire mine up backed into a lake.
    H.L. Mencken
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Or just ask santa for a Jetaway and never worry about it again
    Senior Member wpy3's Avatar
    Pittsburgh, PA
    What about the packing, doesn't that need water to help lube it also?
    Newton Ks.
    Quote Originally Posted by wpy3 View Post
    Not for just a minuite or 2, now if you intend to run it all day on the trailer.........
    H.L. Mencken
