Spark Plug Oil Question
Results 1 to 11 of 11
    Coeur d'Alene, Idaho
    Default Spark Plug Oil Question
    A few times a summer I pull the plugs just to check them...I noticed I always have oil around the threads. The plugs are not fowled and compression is good..is there a problem on the horizon..thanks for the information.
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Quote Originally Posted by Tittyman View Post
    Do you have any oil leaks on the top end? Valve covers or??
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Quote Originally Posted by Wanna_be_CP View Post
    No oil leaks..Autolite Racing Plugs..
    a very small amount of oil residue climbing up the plug threads wouldn't surprise with a clearanced engine , alot would cause concern Tom
    Morgan Hill
    One of the biggest problems with an aluminum intake are leaking from the underside in the lifter valley. A small amount is pretty normal IMO. Synthetic oils seem to do this often.
    Like Tom says also, if there are proper cylinder to piston clearance there will be some residual blowby..
    If it uses oil when used, I would check the intake for warpage or failed gaskets. Seen it a fair amount.
    Also if you run your engine pretty cool temperature wise, it will be hard to keep the oil burned off...
    Probably nothing wrong...Mine does it as well (11.0:1 468 BBC)
    GT
    GT
    Senior Member Factory1's Avatar
    It's common for the plugs to be wet like that, but if your tuneup is right you should be burning off the first two threads nearest the business end, ei, they should be dry. If your not, your probably to rich. F1~
    Senior Member GRoper's Avatar
    No problem. Its normal from my experience to have oil on a few of the threads.
    Quote Originally Posted by GRoper View Post
    This is most of the threads on each plug..also if it is running a little rich, how does that effect or cause oil on the threads? Thanks..
    Rich is going to run cooler, lean, hotter, burning off the oil.
    Quote Originally Posted by Factory1 View Post
    Probably would have some oil no matter how lean you ran wouldnt you?
    You run it lean enough and your spark plugs are going to be the least of your worries! Properly tuned and they will all be wet but the first two. When they start to take on a redish brown color you have gone to far. When you start to see silver dots, you have gone to far! Typically your boat will be laying over at this point as well. F1~
